Brass axle bushings for 1/32 scale motorpods
  • Brass axle bushings for 1/32 scale motorpods
    SIPA68 Bronze Axle Bushing (4)
    Yeah these are Slot.It parts but they are .2mm smaller in diameter than the CH02 bushings, perfect fit in the plastic AvantSlot motorpods.
    For what it's worth..."brass" is not really good for an axle bushing for this type car for "hard" use. It doesn't hold oil like "oillite" material does.
    Bronze is simillar, no oil retention. Look at a Slot.it axle after some "hard" use with minimal or lack of lube care. The bushing measures like new, while the axle can be undersize..!
    IF...the bushing is kept nicely oiled, then there's not much problem. I'd doubt that shorter track cars would show much wear either.
