BRM Saubers are in.
  • BRM Saubers are in.
    Well we got very few pre orders on these cars which was a huge concern for me.
    Now they are in and the BRM031 is sold out.
    BRM028 there is still a little stock but not much left.
    We will be bringing in more, but if you want these cars I recommend pre ordering so we can gauge interest.
    Spare parts will be available soon, but not in this shipment.
    What was the final decision for the motor? Red? Pink? Black?
      By the way which ones Pink.
      OK now you know, I think I just hit the Wall.
      Great show live
        These cars are beautiful!
        But a bummer when you take the wing off for the second time showing the wife how cool it is and the "body" magnut comes off with the wing and the wife catches your disappointment...
        Cheers!
        Paul
          The C9 out for a sunset drive....
            Sorry to see the magnet come off, happy to replace under Warranty.
            Very sorry to see the magnet come off, I will gladly fix this under warranty. We have seen a few do this, but no broken wings. You may also check the o rings in the chassis, I have seen a few of those pop out. A fairly easy fix, but again will do the work for anyone who needs that service.
            These o rings are easy to glue back unlike the orange o rings on the first 917 Porsche.
            Any problems with BRM we stand behind the product 100 %
              Alan,
              I'm happy to drop some glue in place to affix the body magnut. Just thought BRM should know.
              Cheers!
              Paul
                I agree, and feed back information to them all the time.
                I agree, and thank you. Have you checked the chassis o rings, I have seen them pull out fairly easily.
                  O-rings stayed in place when I took the body off to remove the plinth mount and the second time to lube it up!
                  Cheers!
                  Paul
                    Good news.
                    I have seen some glued well and others not so good, still like the wing an easy fix.
                    In a heavy crash during the 6 Hour BRM race in Italy I attended I did see a Team detach the wing blade from the uprights, but once glued back on no more issues. Sadly that was my Team. Still we came 4th out of 12 Teams so not so bad.
                    These angle winders, Porsche, Toyota and Mercedes are proving a blast to race here, I hope you enjoy yours.
                      My o-rings have taken leave of the chassis- at least the front left one for now. Is there a "good" adhesive I should use? I tried super gluing but it didn't last and appeared to harden the rubber. I then tried Goop on another but it came free again.
                        I have not had a problem with Gorilla Super Glue
                        Personally I used 3 spots of Rubbrrized Super Glue after cleaning the chasdis and black o ring. I have not had a lot of luck with the orange o rings.
                          Cheers!
                          Paul
                          Yeah, mine came off too which was a little disappointing but no biggie, I just crazy glued it back in place, job done. Not...I glued it in the wrong way so that the spoiler was repelled away from the car instead of being attracted to it.
                          A little acetone and some patients and I was able to remove it and re-glue it in the right way but it was touch and go there for a bit. I almost pulled the wing in two with the force I had to exert to get the little bugger to let go.
                          Anyway, it’s all good now. For those that get one of these cars I doubt you will be disappointed, they are a big improvement in design over the in-line cars IMO. Just remember my cautionary tale above if your magnet falls off.
                          Make sure you re-glue it in the right way!
                            Seen this happen, as well as o rings.
                            A little rubberized Super glue and you can fix both these issues.
                            On a side note the cars we raced in Germany one of the wings came off so I took a wing from a spare car, whoops not all the magnets are glued the same way round. Like Gord is mentioning here the wings magnet repelled the car magnet. So yes make sure before you glue on a magnet if it comes off that it is the right way round.
                            There is not a lot you need to do to race prep these cars but I have strengthened the magnet mount, and the wing to upright joints, plus re-glued in chassis o rings. set gear mesh. Adjust front axle height taking care not to over tighten or you will break the chassis, or strip out the grub screws. Fit tires of your choice, the ones that come on the car are really for display only. The tires under the tray are Hard Compound Shore 30 so only ideally suited to NINCO or high grip tracks.
                            I would put a flat spot on the rear axle for the gear, also take care when fitting the gear not to push hard on the sides of the gear, as you can bend the gear this way. Do not over tighten the motor strap, just snug down. Do check the motor mount screws to the chassis where the can is held to the motor mount.
                            We have seen great racing with the converted Porsche cars here, no one raced a Mercedes at the last race, but I am sure they will come out next time along with converted Toyota entries.
                              "converted"
                              What do you mean by "converted" when speaking about these cars?? John.
