CD132 Voltage
  • CD132 Voltage
    Could I set all of my cars to speed 10 and then just adjust the voltage in my powersupoly to slow them down?
    Yes, I have done that but if you go too low on power the digital system will not work correctly.
      Nice to have a large powersupply but I'm questionning the use of it. I'm using the stock Carrera power supply and it is very rare that we are 4 using the track at the same time.
      When my grand kids come by, I adjust their cars to 4 to start with and then move it to 6 at its MAX.
      If we ever run 5 older people or more, I use the 18 VOLTS Carrera stock power supply and it does miracles.
      For sure running 4X1/24 cars on that same 18 VOLTS stock power supply, it does'nt do a great job but it won't injure my 1/24 cars.
        What about the reverse?
        I just ordered an 18v transformer for my Carrera track that I've been running 132 & 124 with the original 132 transformer which I believe is 14v.
        Would it damage the motors in the 132 to run them at a lower speed on 18v?
          No please don't adjust the amount of power from the transformer. Adjust the cars via the "speed" setting on the Control Unit.
            It works perfect, no arm done on the 132 cars but they will run extremely fast, so you do have to ajust them with the CU; I have both ready to "plug and play" for my Control unit
              After reading this yesterday post, I went and checked the voltage on my 100 foot track, "no cars running" and it reads 13.97 all around with a stock Carrera 14 VOLTS transformer.
              p.s. I do have 2 power taps installed
                That makes sense to me if I were running an aftermarket variable power transformer.
                My question, and I should have started a new thread but...: If you are running both 132 & 124 on the same track and have two separate stock carrera transformers, is it necessary to switch back and forth or can you just use the 124 18v transformer and slow the 132 cars down via the CU?
                  ..... If you are running both 132 & 124 on the same track and have two separate stock carrera transformers, is it necessary to switch back and forth or can you just use the 124 18v transformer and slow the 132 cars down via the CU?
                  It isn't necessary to switch back and forth as far as the track CU and accessories are concerned since they are designed for that environment. And the motors will most likely be fine too. Carrera digital uses PWM to modulate the speed of the cars so you will have 18 volts going through the chip and the motor at all times. It can be said it is easier on the electronics to run with fewer volts, but it won't really be an issue. IMHO the only risk you run is maybe a ghost car's chip might overheat quicker at 18 volts than it would at 14.8 volts.
                  That probably is the only thing that "could" happen, but the only time that's been a problem is with Formula 1 cars driven as ghost cars.
                  But if you turn the power on the CU down to even 80% the difference is negligible. So power up and have fun
                    Sounds good, same as legrandnormand said... good enough for me, it should be here tomorrow.
                      Just use the 18v transformer and turn down the 1/32 cars if you want to.
