Slotit rear end for carrera
  • Slotit rear end for carrera
    Guys wanting to change to slotit rear axle for my ford GT, 1/32 scale. Been looking around, and I'm not sure what size wheels to get. Want to do this so I can change gear ratios and motors. So any Imput would help...thanks...Brad
    Slot.it produces a rear axle kit for Carrera that has the correct pinion / crown gears / wheel sizing. The bushings provided will be incorrect. You can either reuse the stock Carrera bushings or order the correct bushings from Slot.it.
      Ok,thanks, I'll check into that.
