Loose 917 frontwheel
  • Loose 917 frontwheel
    I have a 917 with the "no axle front wheel" set up. One of the wheels flops slightly. How do you tighten these non-axle wheels?
    Jim Norton
    Huntsville, AL
    You must be asking about the 917/30 in 1:32 scale. Mine were loose too. I didn't try to fix it, I just put a solid axle in. I had to trim some of the guide area for the axle. I cut down the front wheels to use as inserts for machined wheels. It's been awhile, but I probably had to use some bushings too.
