Energy-saving mode issue
  • Energy-saving mode issue
    I am facing two issues:
    - After 20 minutes of non-usage the control unit switches to stand by mode and it does not reactivates even if I press any of the controllers buttons. I have to turn off the CU and turn it on again.
    - When I try to charge the speed controllers, after 20 minutes of charging the CU goes to stand by mode and it stops to charge the controllers. I have to turn off the CU and turn it on again at every 20 minutes to start charging again.
    Any suggestions for these issues?
    Thanks a lot!
    For this one- if you have at least one wired controller, you can plug it in and tape/clamp/fasten the throttle down. I have found that after the initial charge, it doesn't take long to 'top off' the wireless controllers.
    For the other one- that's just the way it works.
