Ninco Controller Wiring Pin out
  • Ninco Controller Wiring Pin out
    Hi All,
    have searched but can't find what I am looking for. I have some Ninco Controllers and want to use them with my Drivers stations - utilising aligator clips. However, after I have stripped the ends off them - it appears that Ninco do not use the standard white/black/red wiring convention.
    To save blowing up my controller, can someone please tell me what the pin out /wiring diagram is for the Ninco controllers. I think they use green , white , grey
    thanks.
    Steve, I can't guarantee this, but it's common for a ground wire in a circuit to be either green or black. So the most likely thing, without actually seeing a pin-out diagram is:
    white = white terminal
    green = black terminal
    grey = red terminal
    You'll probably get an actual diagram-based answer eventually, so I wouldn't use this unless you've completely given up on getting that answer.
      Check out Greg Braun's excellent page on controllers. Scroll down a bit and you will find a graphic showing the "plug" outs.
      Pete
        thanks guys - white = white terminal
        grey = red terminal
        is totally correct - all working now.
