Converting Scalextric Track Codes
  • Converting Scalextric Track Codes
    I just dug out some old track I bought 8 or more years ago.
    The various segments are coded
    A
    B
    C
    D
    EA
    E
    F
    K
    N
    S
    W
    Does anybody know the conversion to the new C8xx designations used today?
    Thank you
    Here you go.
    You might also want to check out Slotict's Layout Archive, here.
    to SCI!
      Thanks!
      Thanks a bunch! Now all I gotta do is get the Scalextric's track designer to work.
      I'm trying to pull together a 4 x 10 layout that has room for the borders.
        Not updated this in a while but I have the codes on my Store Site.
        http://www.132slotcar.us/store/produ...oducts_id=2450
        SCALEXTRIC TRACK CODES
        CODE PART# DESCRIPTION
        A C8217 Power Base
        B C8205 Standard Straight 350mm (2 pieces)
        C C8206 R2 Standard Curve 45 (2 pieces)
        CB C8296 R2 10 Banked Curve 45 (2 pieces)
        D C8207 Half Straight 175mm (2 pieces)
        E C8203 R2 Racing Curve Crossover 90 (2 pieces)
        F C8200 Quarter Straight 87mm (2 pieces)
        G/H C8246 Side Swipe Straights (2 pieces)
        J C8201 R1 Hairpin Curve 90 (2 pieces)
        K C8202 R1 Inner Curve 45 (2 pieces)
        L/M C8211 Leap Straight Ramp up + Ramp down
        N C8204 R3 Outer Curve 22.5 (2 pieces)
        NNB C8297 R3 10 Banked Curve 45 (2 pieces)
        P C8210 Straight Crossover 90
        R C8222 Classic to Sport Track Conversion 175mm (2)
        S C8235 R4 Outer Curve 22.5 (2 pieces)
        T C8236 Short Straight 78mm (2 pieces)
        U C8234 R2 Standard Curve 22.5 (2 pieces)
        V C8278 R1 Inner Curve 22.5 (2 pieces)
        W C8295 Elevated Crossover 90 or 180 233mm
        X C7007/C7010 Lane Change Curves Radius 2 90
        Y C7008/C7009 Lane Change Curves Radius 2 90
        Z1 Lane Change Sensor Half Straight 175mm
          Good luck.
          Be sure to run as administrator.
          If it still crashes a lot, just give it up and go to Ultimate Racer 3.
