BRM and other Questions for Newbie
  • BRM and other Questions for Newbie
    I have a very large collection of 1:32 cars that I have collected over many years. I am now starting a large scale track to go with my HO layout.
    My track will be two lane routed MDF with mag braid about 87-feet long. The lane spacing and shoulders will be wide enough for 1:24 as well.
    So I started looking at 1:24 offerings and saw the BRM cars. They look really nice and have bodies that interest me. Questions:
    Do BRM cars run well out of the box or do they need tweaking?
    Are the chassis/motors similar such that two cars can run evenly?
    Do they run similar to Carrera cars so they can be part of the mix?
    I am a recreational racer and am not looking for all out racer cars.
    This is my track plan as of today:
    Plan 003 by bonez 300
    This will go with my HO layout in my toy room:
    Overall 003 by bonez 300
    Overall 005 by bonez 300
    Hello
    Which BRMs
    First comparison - BRM 1/24 cars run at 12v Carrera 1/24 run at 18v.
    BRM cars don't have a magnet installed though you can put one in most (if not all) of the cars. Carrera 1/24 have two magnets like there 1/32 cars.
    Most BRM now have a metal chassis. The Porsche 962 and other Group C cars have a plastic chassis available as an anglewinder though the earlier ones had an inline chassis. I understand they will be doing a metal chassis for the Group C cars soon as well. The early Porsche 917k also had plastic chassis.
    The BRM Trans Am cars are quite similar - same motor same chassis parts just a slight difference in the chassis plate. I run mine without a magnet. I also changed the tyres to urethane ones from Paul Gage but you can use the stock rubber or buy softer BRM rubber ones as well. They run quite well handle nicely - they do need some basic tuning - tyre truing etc.I have found the brakes not as strong as Carrera cars.
    The Group C cars - I haven't raced them yet only driven them for fun. They also run well. We put the magnet in them though I think we will end up removing it. Once again tyres and basic tuning.
    I have two Porsche 917k and a Ferrari 512M one Porsche has a plastic chassis the other two have a metal chassis. They all run well no magnet - once again tyre change to urethane.
    Lastly you have the BRM mini-saloons. NSU, Simca, Fiat, Escort, Mini etc - these are great little cars - the stock tyres hook up nicely. They are a bit quirky in the rear axle as the wheels have camber but they run well. We race them no magnet. Across the models there are pluses and minus for each car - some are a little top heavy etc but with basic tuning they go well. We raced them Saturday and from memory a Mini, an NSU and Renault finished on the podium. Don't think anyone raced the little Fiat and no one had an Escort yet.
    Carrera 1/24 are a lot of fun to race - they are fairly evenly matched across the GT3 cars - like all slot cars one car may prove a bit quicker than another. I won all my heats on Saturday running an Aston, Mercedes, Corvette and Porsche 911.
    The classic are my favourites beautiful cars. I find my Ferrari 512s quicker than my Porsche 917k but a mate has a Porsche that is closely matched to mine. I have a nicely tuned GT40 as well. Mainly tuning is tyre set up and because we run them with magnets there is a bit of tuning on the magnets as well - there are plastic shims to adjust the position.
    cheers
    David
    PS great looking tracks
      The Gp C BRM's set up box stock (red motor, shore 30 tires) are probably our most entertaining and enjoyable class. They run OK out of the box but with some attention applied to truing the tires and setting the gear mesh, they can run silent and fast. They are superbly entertaining. We spec'd box stock to take the mystery out of parts selection to focus on tuning and driving. The only deviation we allow is using Parma gears for the inline cars as the stock BRM were not terribly robust.
      Our main club track is 3 lane copper tape MDF with wide enough spacing for passing in the corners. It does have a little bit of magna-primer on it so we do get some stick from the magnets but it just goes along with the ground effect nature of the cars in real life. They are a blast.
      We've also run the Trans Am cars occasionally and the GT cars once or twice, and they are also fun but more complicated. The Gp C make an excellent spec class.
        BRM's are great in my opinion as long as you run them in their classes - Grp C, Classic, TransAm, Mini's,GT. For anything BRM give Alan @ Scaleracing a ring 1 253 255 1807
          I would like to clarify a term often used in this Industry.
          RTR. Ready to run is a term often used. I even see it often on my Store Site www.132slotcar.us I need to change that as almost no car is ready to run out of the box. Maybe Scalextric and Carrera on their own track systems.
          Certainly cars with adjustments can not really be ready to run let alone race as supplied.
          On BRM we bulletproof bodies, lubricate axles, gears etc. Were adjustable setting axle height on the front is critical to good handling and brakes. Truing tires and choosing the right tires for your track are a must.
          Breaking in gears after setting mesh and resetting after break in before racing are also very important.
          Also where used screws should be loctited in place, and covered by clear tape to prevent loss on track.
          To document set up on BRM cars would take a lot, and depends on the Class. But to be brief:
          Group C inline
          True tires we fit lowered fronts.
          Set guide correctly with lead wires containing the o ring on the first gen guides. Or switch to the sprung guide ( used either sprung or shimmed )
          Switch with Sigma "S" rear crown gear. Set rear axle with zero float and check this often as any float changes gear mesh which can destroy gears. Set crown gear with zero lash at tightest spot and mark gear so you know where that is. As gears bed in this will change. Lube with good gear grease( we sell it )
          Make sure driver, cockpit is assembled corectly and glue in driver and accessories or they tend to dislodge in a crash.
          Make sure the underside of the cockpit tray is flat, sand off bumps. Shorten countersunk screw as it will hit the underside of the drivers seat before tightening. Snug tight screw and cover with clear tape.
          OK that is a start. I will look into building some build up files in the BRM section on SCI.
          A quick note, the Trans Am cars if bought from the ScaleRacing/BRM production ar very close to Ready To Run as I build them all.
          Screws are loctited, motor and gears set and mesh broken in. Everything is lubricated. We do not true tires ( we could if wanted ) We do extra work on the bodies we tooled in Partnership with BRM. Drivers glued in and seat, fire extinguisher, steering wheel. Glass is reglued, interior heat glued and Shoe Goo'd in place.
          We recommend bulletproofing bodies, we do not do that as some may not like
          the extra Shoe Goo we use. But bodies last much longer in hard racing once done.
          OK now I have to go build cars to ship out to Dealers and Customers.
          More later.
            Look forward to more tips Alan - these are great cars.
            cheers
            David
              Here's my $0.02 Bonez - for all intents and purposes you can run a BRM just fine (fresh out of the box) on your custom routed MDF track once completed. Will it be noisy and possibly wobbly? Perhaps. I'd guess on a scale from 1-10, 10 being what Alan ( Scaleracing ) mentioned (minus racing body prep), right out of the box ranges from 5-7. You're going to want to at least achieve an 8 when your track is completed because it makes for a more enjoyable ride. In fact, I'd bet you'll want to reach a 9-10 on every car you want to run because the surface will be so smooth if the car isn't set up perfectly you might not like the way it handles. Its on a different level than plastic track. Something I really don't have to worry about because my track purposely has dips and cracks and pinches. I need my cars front wheels to touch the track - when your track is done you won't want them to I think.
                Thanks all for the helpful responses. I always like working on my cars to make them run smooth and fast.
                Another question - are the BRM bodies detailed with good paint and graphics? The photos look pretty darn good.
                I am mostly a model car racer that enjoys accurate liveries, shape and stance as these rolling pieces of history run on my scenic tracks.
                  BRM bodies are stunning - beautiful paint and tempo printing - excellent detail and robust cars.
                    Originally posted by Bonez View Post
                    ...Another question - are the BRM bodies detailed with good paint and graphics? The photos look pretty darn good.
                    I see a Fly set you have in your case Bonez - the Team Shell yellow Porsche 917K and Ferrari 512s CL - I have that set also and they are the best looking cars Fly produced IMO. The colors are stunning and the gold wheels on the Ferrari look real. BRM's look as good, if not better than that Fly Shell set.
                    I'd post a pic I took.. but I Can't!! **** Quota - when will someone fix this??
                      Since you have a lot of die cast, are into trains, and have a fully sceniced slot and train layout, Id say the BRM cars would be right up your alley. Paint and detail are fantastic, possibly to the point youd hate to crash one into a wall or another car. Not a big choice of cars and many seem hard to find these days.
                      I started with a used Lowenbrau 962 to get my feet wet. Ive since picked up a new one in that scheme along with the Miller, Bud, and Coke cars, a 917, and my favorite - a Ferrari 512. The last car required a bit of head scratching to get the chassis fixed.
                      The one thing Ive found is lack of brakes. The cars seem to coast quite a bit.
                      Go for it!
