Fun Small Layout 42" x 96" Board
  • Fun Small Layout 42" x 96" Board
    Here is a fun little layout for Guys that don't have a ton of space. Enjoy!
    That IS a fun layout. Lots to it, but not too complicated.
      I like it! Any chance of a schematic? The pic is too small to accurately make out the sections/curves used.
      Brian
        That is nice.
          Don't have a schematic, but can give you a track list. I can take closer pics if needed.
          24- 15" straights
          2- 6" straights
          11- 9" 1/4 curves
          3- 15" curves
          9- 12" curves
          21- 6" curves
          5- 9 1/8 curves
          2- 12" straights
            Very nice. That's a good AFX Magnatraction or Non-Mag layout.
              Closer pics taken from as straight overhead as possible would be a big help! Thanks!
              Brian
                24- 15" straights
                2- 6" straights
                11- 9" 1/4 curves
                3- 15" curves
                9- 12" curves
                21- 6" curves
                5- 9 1/8 curves
                2- 12" straights
                Thanks, if you get some good shots, I will plug it into a track layout program and post the picture. You get naming rights of course!
                  I worked it out (maybe) on Tracker 2000 and this is what I came up with. On a 4x8 board it just fits lengthwise and does not really leave room for turn borders which I would want.
                  I attached these as PDF files, the first filled in, the second sort of a skeleton view, because the limit on posting jpegs was too low to be useful.
                  Scott McCrate
                    Here's a revision that opens out some corners but shortens the overall length to allow space for turn borders on a 4x8 table.
                    Pretty nice layout with room to tweak it.
                    Scott
                      That is pretty close. Long straight has only 5- 15" straights. Otherwise that is spot on. There is room for track borders on your 1st layout if desired. Thanks for the PDF. Nice work!
                        That is pretty close. Long straight has only 5- 15" straights. Otherwise that is spot on. There is room for track borders if desired. Thanks for the PDF. Nice work!
                        Cool, I will have to mess with it a bit more.
                        Scott
                          Was the track built with Tomy track? I assume so. You indicated in the track part list 2 - 12" sections, but Tomy doesn't make a 12". When I worked it out by zooming in, I couldn't quite make out some of it.
                            Sorry....that is 2- 9" straights. Yes it is Tomy track. I just start snapping track together until I ran out of space. I'll try your revised layout tonight. It cuts out a few 6" turns.
                              Very nicely done! I'd love to run some of my favorite Aurora (non- competition) T-Jet cars on that one.
                              Thanks for the look, and... Enjoy! -- Ernie :>)
