Help. HSSRMS
  • Help. HSSRMS
    I just can't get everything working correctly. I've tried different ports and latency times as suggested in the forum. About 7 laps out of 200 have registered a time. I did get 3 laps in a row to be timed. 95% of time cars don't register. Program won't shut down unless I use task manager. An alert says no 132 timer can be found. The Carrera lap counter and app connect work ok. I'm using cable from DRS. I'm just need help on what I'm doing wrong.
    Welcome to SCI If you go into the Carrera forum,the first thread [alternative software.......] is about the software that you are using. If you post your questions in that thread you will surely get the answer faster.Bruce Yingling,the creator of the program,posts there regularly. It may not be seen by as many people here.
    Randy
