H&R 1/24 chassis
  • H&R 1/24 chassis
    anybody know the track width (out to out) on these?
    i just got a '70 Celica model & i'm sure i'm gonna hafta flare the wheel wells, just how much?
    i don't know the answer, but i do know that they make 3 or 4 different width wheels so you might be able to narrow the stance that way rather than resorting to flares.
      oh, no, I wanna flare it!
        They are inlines with rather generous axles and have rather wide tire options available. Set your gear up and just slide the wheels out as wide as you want to flare it. I am pretty certain you'll be able to get it as wide as you'll want.
        I have a chassis but no pics online. I can check in the morning if you want.
          Didn't grab a pic but gear mesh is held by spacers on the axle between the wheel and the axle bracket. You can put in whatever size tires you want and push them as wide as you want with reckless abandon, just make the appropriately-sized spacer to hold the crown against the pinion with the wheel in the correct place.
          Does that make sense?
          CK
