Carrera DTM Series Specs
  • Carrera DTM Series Specs
    D.R.A.W.W. SERIES SPEC SHEET
    (Subject to change no later than the first race of the series.)
    FUNDAMENTAL SPECS
    Brand: Carrera
    Type: DTM (old or new chassis)
    Magnet Location (if present): NO MAGNETS
    Rear Tires/prep: Carlos' Urethane tires, may be glued and trued
    MODIFICATIONS ALLOWED (otherwise Box Stock*)
    Front tires/prep: stock tires may be glued, trued, and coated for grip reduction
    Added Weight: no more than 10g added weight, any type, any location inside car.
    Guides: stock may be thinned/trimmed for Sport track, or BRM replacements. Centering spring may be removed for better LC reliability.
    Braids: Stock
    Wiring: May be replaced for lighting and chipping purposes, or use stock.
    SSD Chip: Stock Scalextric brand chip with no component replacements or code changes
    Chassis: stock
    Screws (body/pod): stock, must not fall out (use tape if screws are loose)
    Gearing: stock
    Motors: stock
    Pods: N/A
    Wheels: Stock
    Axles/Spacers: Spacers Allowed
    Interiors: Stock
    RACE FORMAT:
    HOUSE RULES! Run the race at your track however you want to.
    Points assigned to winner of each race meeting toward placement in series will be 10 for winner, 8 for second, 6 for 3rd, then 5, 4, 3, 2, 1. Any present racer earns no less than 1 point.
    Series will consist of ten races, twice at each track in the group.
    There will be one "take out" for the series championship. If you miss a race, that will be your take-out. Otherwise, lowest of earned points will be removed at the end of the series to determine final placement for the series.
    Race Format updated. House Rules for all race meetings. Points toward series placement remains.
      Greg, have you considered allowing the GT cars in the mix to give more variety?
        Not until now, and now it's a bit late as we all have DTM cars.
        However, that brings up the question... do DTM cars ever share the track with GT cars in an official race? I thought DTM was a class that tended to race on its own.
