Next Series NSR Classics
  • Next Series NSR Classics
    NEXT SERIES NSR CLASSICS
    With no changes from the last time we ran them we'll be using the same spec's as before with the addition of the 908/3
    CARS : FORDS MK1 , MK4 and P68 - PORSCHE 917 and 908/3
    SPECS :
    MANDATORY
    Min weight 66 gm - Max down force 12gm
    Screws : tight or loose - stock or tuner
    Tires : Fronts stock , Rears : NSR Super Grip ( no ultra )- Both GT 40's (NSR 5236) 20 X 10 - for the 917 , 908/3 & P68 (NSR 5253) 20 X 11
    MODIFICATIONS
    Added weight : none
    Chassis : stock BLACK
    Gearing : stock 11 tooth pin - 32 tooth crown
    Guides : any NSR
    Braids : any
    Interiors : stock
    Motors : stock NSR 20 K
    Pod : stock BLACK or RED sidewinder
    Wheels : NSR (5002) 16mm air
    Wiring : stock , may grub to guide
    Miscellaneous : Tires may be glued and trued
    ( I will gladly true your tires if glued to wheels and ready to go )
    Anything not mentioned in the modifications shall remain in it's original application.
    Not much has changed from the last time we ran these but any questions or suggestions are welcome .
    Pat
    Lola T70 ?
      Tim , that would be great . I'm not sure they make one , Haven't seen one as of yet anyway .
        I could have sworn I saw one somewhere.
        Guess not
        tim
          Hey , Happy Birthday anyway ! 51 ?
              Just a bump for the next series
                bump
