Next Series - Scaleauto 1/32 GT3
  • Next Series - Scaleauto 1/32 GT3
    SPECS :
    MANDATORY
    Scaleauto Modern GT Class: Mercedes SLS GT3; Honda HSV-010; BMW Z4 GT3; SRT Viper GTS-R; Spyker C8 GT2-R; Pagani Zonda; Porsche 991 RSR.
    - The newest models come ready to race after magnet removal and rear wheel/tire change. Older models may need a motor replacement, some may need a new pod, gears, and guide as well. Models made for sidewinder pods will probably need a lexan interior or a lot of interior modifications.
    Magnet: must be removed
    Min weight 75 gm
    Max down force (15gm TBD)
    Screws : stock. tight or loose
    Tires : Fronts - stock. Original rears may be moved to the front
    Rears - Scaleauto red stripe foam rubber. SC-2009N recommended, but can be any size as long as it fits within the car's stock fenders.
    Wheels : Stock front, red stripe rear
    Motor : SC-0011b
    Pod : RED anglewinder
    Gearing : stock. Black 27t Anglewinder spur gear and original white nylon pinion
    Guides : stock red. Should be home guide type SC-1620, not the kind with the angled front end
    Chassis : stock
    MODIFICATIONS
    Added weight : up to 7g, one piece, any location
    Braids : any
    Interiors : stock or lexan if converting an older car to spec
    Wiring : stock , may use grub/set screws in place of eyelets to hold wires in guide
    Tires: Front tires may glued, trued, and coated to minimize grip
    Anything not mentioned in the modifications shall remain in it's original application.
    what he said
      well, my spare Z4 borrow car, is better then my Viper. installed the alloy rear wheels to the front installed shims and grub screws. I should race this one instead of the Viper. Oh well, i'll still let Russ run it.
        I understand the minimum weight but out of curiosity why do you limit how much weight you can add?
          what he said again
            bump
