Race Info Feb 13 Racer D/P and 1/24 Scale Auto
  • Race Info Feb 13 Racer D/P and 1/24 Scale Auto
    Details:
    Doors Open at 9am
    Tech is at 11am
    Race Starts at Noon
    5min Heats
    1.5mins in between
    Cost:
    $20. Both Races and practice
    (All Day Access to the Track)
    ********NOTE********
    The Only additives that are allowed on the tires are...
    Scale Auto SC-5300 Sponge/Rubber Tire Cleaner.
    NSR Tire Oil NSR4605.
    Lighter Fluid.
    ***If you are caught putting any other tire treatment or additives on the tire at anytime you will be disqualified from the race. NO Exceptions.***
    1st Race
    Racer Sideways Daytona Protoype
    Rules
    Cars Allowed: Riley MKXX, Dallara DP
    *White Kits are allowed But must be painted and have 3 numbers in the correct size and position of that style of car*
    Motor: Stock Slot it Orange Bell 21.5
    Motor Pod: Inline or Sidewinder
    Spur Gear: Any Slot it
    Pinion: Any Slot it
    Front Tires: Stock or any Slot it
    Rear Tires: Any Rubber or Urethane
    No Magnets allowed
    Guide: Any Guide
    Braid : Any braid is allowed
    2nd Race
    1/24 Scaleauto
    **Wheel inserts must be in**
    **Wing must be on at the start of the race**
    Spec Tire: Scale Auto Sponge Tires .
    Spec Motor: SC-0025 or SC-0026 with a Gear Ratio 12:44
    We will be following the national rules
    See Link for rules http://www.slotcarillustrated.com/po...ad.php?t=52703
    *** If you do not see it in the rules or you are unsure please contact me ***
    Thanks Phase II for hosting a great event.
    That was some fast racing!
    A special shout out to car-owner/motor-expert Little Gary
    Thanks Little Gary, you rock!
    The 6-h SA is going to be nuts!
      He was so excited to here that his car won the race
      mabey I should let him run in all my motors
        SA was very fun and very fast. Lots of very good drivers in the field. ~Ron
          So great to hear
            Link to the rules above isn't working. i assume these will be used for the upcoming 6hr race?
              Porsche Joe
              Look on SCI under forum/ Scaleauto 2015 rules are listed at the top of the page 1. I'm not sure if we are going to run foam and rubber. We did that with the 6 hr BRM race. Pit stop in middle of race to change tires. My guess is we will do that with the SA race. Even if we don't do it for the 6 hr sometimes we race on rubber instead of foam. Phase 2 Rules are usually posted a week to 10 days before the race I wish they were sooner but Greg has a lot on his plate. ~Ron
                So will it be any compound of rubber or foam, or will the compound be dictated? I am trying to avoid ordering stuff I don't need, but also don't want to wait until 10days before the race to figure out the tires.
                Thanks for the help.
                  I am setting up for both ScaleAuto rubber and foam, no other manufacturers wheels or tires. I expect there will be a tire change component to the race.
                  Follow national SA rules until official rules for this event are posted.
