1/24 Scale Rule Package
  • 1/24 Scale Rule Package
    BRM Group C Rules
    - Any BRM Porsche 962 or Toyota 88C or Sauber C9
    - Stock Kit Tires or BRM 22 Shore Rubber tires or Super Tires (Silicone only) - No Chemical Treatment permitted.
    **The tires will be rolled on glass before the race - ABSOLUTELY no residue can be left on the glass**.... if they do leave any type of mark an alternate set of legal tires must be used
    - Stock BRM Red or Pink Motors Permitted
    - Red Motors -8T or 9T Pinion, Pink Motors must run a 9T Pinion
    - Stock Guide or New BRM Bolt in guide Permitted
    - BRM 34T or 36T Crowns Permitted
    - All Cars must weigh a minimum of 185 Grams on the House Scale
    - Front Tires must both be Fully on the Track - Tires must not be visible looking downwards at the car
    - All details must be on the car to start the race. (Mirrors exempted)
    - No Body or Chassis Modifications Allowed - No Lightening of any Kind
    Cars will race on 5 lanes with 4 minute heats. Total Race time 20 minutes - Track Voltage - 11V
    BRM Porsche 917 / Ferrari 512s Rules
    - Any BRM Porsche 917 or Ferrari 512s Permited
    - Tires are Open
    - Stock BRM Pink Motor Permitted
    - 11T Pinion with the 38 or 41 Spur Gear Permitted
    - Cars can run the Stock Guide with a guide nut or O-ring to secure it. - The New BRM Bolt in guide is Permitted also
    - Front tires must both be Fully on the track - Tires must not be visible looking downwards at the car
    Cars will Race all 5 Lanes with 4 minute heats. Total Race time - 20 Minutes Track Voltage - 12V
    1/24 Scaleauto GT Challenge Rules
    - Any 1/24 Scale Auto Car Permitted
    **It is not permitted to modify the RTR car or white kit in any way. (Other than crash proofing the Body with Shoe Goo - Excessive amounts will have to be removed.)
    Tires
    - Stock Rubber kit tires Permitted
    - Scaleauto Hard Comp Tires Permitted for the Front
    - Scaleauto Pro Comp 3 Tires Permitted for the Rear - 13mm Width Maximum
    ** Tires MUST have the Factory Markings on the Sidewalls**
    - Tires can not be visible from above the Car including the body float
    - Wheels Must have Inserts installed
    - ONLY Scaleauto Tire Cleaner is permitted. SC-5300
    Motor
    - Stock Scaleauto Motors Permitted SC-0025b or SC-0026
    Guide
    - Stock Scaleauto Guide Permitted - Can be fastened with a Steel Guide nut or SC-1629 Nylon Guide Nut
    Chassis
    - No modifications allowed
    - 8mm Front Uprights required (This is the Stock Front Upright)
    - 10mm Rear Uprights required (This is the Stock Rear Upright)
    - Ball bearings permitted - Older cars can upgrade from bushings
    - Carbon H-Plate permitted
    - T-Nuts with or without Springs Permitted
    - Minimum Ride height - Pre Race Tech - 1.5mm Front and Rear - i.e. My Ride height gauge must slip under the chassis on the 1.5mm marked tooth.
    - Maximum Rear Track for any car is 83.5mm (measured at the widest point of the axle assembly)
    Body
    - No modifications allowed of any kind
    - Body MUST have "float", ie It Can NOT be fastened to eliminate body movement.
    - Scaleauto Lexan Interiors and Glass may be used. Interiors must be Fully Painted and Detailed. Roll Cage must be installed.
    Gearing
    - 12T or 10T Pinion Gear permitted - Any manufacturer permitted
    - 44T Spur Gear Permitted - Must be a Scaleauto Gear
    Race Format
    Cars will run on 5 lanes with 4 minute heats - Total Race time 20 Minutes - Track Voltage 11V
    A Note on this Class - READ THIS!!!!
    Scaleauto, Scaleracing and Race Haven Hobbies are determined to create a new philosophy for Model Car Racing in 1/24th scale. A form of racing where the Racer not only desires to perform but also understands it is critical to protect his car from damage. To that end, major body parts must remain fitted to the car at all times during racing. Any repairs MUST BE DONE UNDER “GREEN” CONDITIONS. The track will not be turned off, nor the race stopped to allow a crashed car to be repaired no matter who caused the damage. Drivers must not Marshal cars.
    No Car under any conditions is to be Pushed out of the way. A Car across your lane means you stop until the car is moved from your path. Clean driving is promoted in this class. Reckless or Unsportsman like driving will be subject to a warning on first offense. A second offense will result in a 1 Lap Penalty for the heat in question, A third offense will result in a 2 lap penalty for the heat in question and so on. All Penalties will be at the Race Director discretion. Witness accounts will be taken into consideration also. Racing Incidents are exactly that and will not be penalized. I have spent many years around race tracks and I can assure you I know the difference between Racing Incidents and Reckless driving. Drive clean and protect your car - Do this and we won't ever have any problems, or broken cars, This is the Goal.
    Any Questions??? Please ask me in a PM, Do not Post here.
    Ron
    Race Haven Hobbies
    www.racehavenhobbies.com
