Reference - U13 2015 - Tires used
  • Reference - U13 2015 - Tires used
    Tires for U13 - sorted by position.
    IF ANY OF THE OWNERS/CARS WITH NO DATA WOULD SUPPLY THAT INFORMATION IT WOULD BE HELPFUL FOR NEXT YEARS BUILDS
    ref: U13 2015 Photos - post 18 Spread Sheet
    Note: Northeast (US) tracks are Silicone tracks
    4 of the top 6 positions used Paul Gage, 2 of the top 6 are Luf's Urethanes.
    Of the cars with known data, tires used:
    Paul Gage = 9
    Luf's Urethanes = 3
    DART = 3
    (Sorry my tabs don't translate to the thread content.)
    No. Owner / RearWheel / Rear Tire
    U Class
    36 Brain CBD 14X6 Insert PG 20062V
    45 RetroRacer44 BWA 15x200 Luf Ureth.
    15 mether05 CBD 14X6 Insert PG 20062V
    7 Doubl-B UK RS Slots Paul Gage
    72 Black3se DART DART
    177 Aloha stock Paul Gage
    5 jeremy5 no info no info
    2 JTPrevia no info no info
    13 MRollingThunder BWA DART
    95 Jrlang BWA 13"Dbl Flange PG PGT 20x6
    23 Alexisin Greece Penelope Pitlane CB Reprotec
    UX Class
    79 TF1250 Slot.itF1 Luf Ureth.
    11 Doubl-B SCC 14x8 Insert Paul Gage
    8 VtechFour Ranch Design 13x6 PG20084
    44 RetroRacer44 Mr. Slot Car Luf Ureth.
    63 Brain SCCF1 Paul Gage
    72 Black3sr DART DART
    31 MRollingThunder no info Paul Gage
    33 BrumosRSR Slot.it 15x8 NSR Super Grip 18x8
    5 NTZ noinfo noinfo
    22 JTPrevia no info no info
    162 Aloha Slot.it Yellow Dogs
    4 Alexisin Greece Slot.it PA33als Mitroos M001
    Retro's Alfas
    My U class winning Alfa has BWA 15s all around and Luf urethanes on rear.
    My UX had the wheels from a MRSlotcar Mazda all around, and Luf urethanes on rear.
    I realized that the first track ran silicone tires but didn't realize they all did in the US hub. That would explain the changes in results as the cars came to the all-urethane tracks in Canada, eh?
      Thanks! Updated SS and list
        Hi Mether05,
        One other small point and wonder if others have found this as well: I used Luf's urethane's on the front as well as the rear of my Lotus because I find urethane tires so much easier to true than rubber tires. Any time I've tried to true rubber tires I end up with a soggy, half melted mess. I suspect (read know) my truing method is not remotely close to perfect, but given the option, I would far prefer to true a urethane tire (in minutes) than a rubber tire in a portion of an hour.
        Also, I usually do coat my trued urethane tires with either nail polish or CA to reduce the coefficient of friction.
        Don
          How does one purchase Luf urethanes? I wouldn't mind trying some.
          BB
            You can go to Luf's website www.oldslotracer.com Hit the "email me" button, and a mail form will pop up.
              Hi Retro Racer - Luf's link does not work. Should it have "d" in it?
              On tracks that use silicone all this means to me is they will be perfectly clean. Do not think this should be a problem for urethane tires. Main thing probably is that once event starts no silicones should be allowed until over. Particularly important for anybody running rubber tires.
              Regards Chas Le Breton (charlesx)
                d
                Your right, it is fixed now.
