Just chipped a new Scaley Camaro with a Carson DPR chip. The car won't work in the pit lane. The Carrera cars work but the Scaley Carson chipped car doesn't work. Has any one else had this problem? If so what can I do to fix it????
When you say won't work in the pit lane- do you mean it won't run at all when in the pit lane?
Or do you mean it won't refuel? And if you mean it won't refuel- why are you still running a Black Box system instead of a CU with the advanced pit lane?
I'm using the CU, the DPR car won't run/doesn't work in the pit lane. The weird thing is that if a another car is in the pit lane, meaning regular D132 car, the DPR Cara will run. But if there's no other car in the pit lane at the same time the DPR car won't even move.
It's an older CU, from 2012 or 2013 that has not received any firmware updates. Could that be a factor?
I don't know, Carlos. I've never used a Carson chip, but I know they don't include ghost and pace functions, so figured they wouldn't calculate fuel on a Black Box system.
If you remove the internal jumper on the pit lane entry switch that sends the low phase signal to the pit lane, and put a 'normal' jumper into the pit lane, the Carson car will probably run properly. Without that internal jumper, the pit lane voltage signal will be exactly the same as the rest of the track. On a CU system, you don't need that jumper unless you're using this pit for a pace car.
Hey Bruce, I'm using the CU, no BB, with a newer Pit lane track, the one that came with the Pit Lane adapter track included. If I remove the jumper you're referring to will the pit lane features still work?
Did you disconnect the ferrite man and any other electronic components that connect the + and - leads together?
Best regards,
Brian
Hadn't thought about that. I didn't want to butcher the car too much since I only plan to use if a couple times. But I will try removing the ferrite beads tonight.
They will. With a CU and an advanced pit lane, the jumper's only purpose is to let the pace car 'know' when to stop. If Brian's advice pans out- be up to you whether you want to slightly modify your track (and fix it for any future cars with the Carson chip) or modify this car.
We're going to be racing all Carson DPR cars this weekend on my Carrera digital track; I want to be sure they will all work. I ran a different DPR car on a friend's Carrera digital track a few months ago and we didn't have this problem. He didn't need to do any modifications whatsoever for it to work. I'll try to figure out which wire to remove and see if that helps.
For future reference: it would have been the red wire that connects to the curved, inside rail. The two that connect to the straight outside rails are how the chip draws power. The red wire leading to the pit lane rail is the one that sends the low phase voltage signal to the pit lane.
Your other pit entry switch really shouldn't have been any different. They all have the same jumper in them. In fact, the pit entry switch performs exactly the same old pit or new. I guess it's possible the chip firmware is different. I'm wondering if you happened to have found a hyper-sensitive Carson chip, or if you have a slightly out of whack pit entry switch.
I removed the capacitor and the problems were solved. The ferrite bead can stay in place, but the cap needs to be removed in order to work with Carrera digital timing and scoring.
I have a friend who didn't have a problem with his Carson chipped cars, I'll see them this weekend and try to find out why.
