If this is your first visit, be sure to
check out the FAQ by clicking the
link above. You may have to register
before you can post: click the register link above to proceed. To start viewing messages,
select the forum that you want to visit from the selection below. This Forum is brought to you by ScaleRacing LLC and their Store www.132slotcar.us
This one is a fixed setting, I would probably have set it on max anyway but rather than cut out the middles of the trays to make room for only one filament roll I've made a circular wall for the lid to sit on with expanded plastic and it's tall enough for two rolls at once.
Mine doesn't even have an on/off switch, let alone temperature control or even a thermometer. It's a straight up AC heater coil and relies entirely on the convection of the heated air. But, I can't complain for a few bucks from Goodwill. ;-)
I do plan to get something with a little more control at some point, with forced air to boot. Hopefully from a thrift store again.
depends on how bad they were. I usually leave a roll in at least overnight, and sometimes for multiple days if it's being problematic.
That's one nice thing about the color changing dessicant. when you take a roll out and the color has changed completely, you know that the bag has holes, or the filament is really wet (usually wet because of the holes) and it should be left in the dryer a while.
With the dehydrators with fans and variable settings, it can usually be done faster, though still counted in hours as opposed to minutes.
PETG had 6 hours in the dryer yesterday and stored in a sealed tin with silica. Printed a pod tonight and I have to say the definition is definitely better.
