I am having some trouble with my Hammer M controller - it won't work keeps showing a short circuit.
Anyone out there using the Hammer M with a power supply other than the Avant Slot one? I have a 40amp 5-15v regulated power supply. I run on a wood track with copper tape.
I have made a connector which connects the Avant Slot Controller up in the manner that I believe is correct based on the manual. White has + feed from the power supply - Red goes to the + side of the track and Black is the - (neg) feed from the power supply and then to the negative side of the track.
When I connect the Hammer M to the track the green light comes on the display shows 1, 2 u then some other numbers which tells me 12v and the settings, I can press the buttons to change settings etc - I have a car on the track when I plug the controller in but when I pull the trigger to make the car go the controller cuts out and the short circuit symbol (square) appears on the display.
I currently have a slot.it controller and 2 Parma controllers and they work fine. I have had friends use their controllers with out a problem so I am unsure where the short circuit has occurred.
I was hoping there may be someone out there with some experience with this problem who would be able to offer suggestions I am not sure what I am doing wrong.
I have contacted Avant Slot and they offered some suggestions which didn't fix the problem
cheers
DM
cheers
DM
