Boopie, if you leave the pod in the chassis, it will help align everything. After straighteneing, I check bushing alignment on the chassis jig just to be sure.
Chassis flattening
High temp required on many Chassis.
Boopiejones, that procedure works fine on some chassis, will not touch an Avant Slot. nor BRM. They require higher temperatures. This is part of the discussion here. The normal way, as suggested by Slot.it will not straighten some chassis, but slowly up the temp and you can usually get the results needed. Timkoul's temp is very high so just making sure he is doing it the same as you, and I described.
I have a machined flat metal plate, but otherwise I am doing similar to you. Higher temp water, I boil in a kettle before filling the flat glass pan. Then I sit in an oven at higher temp than you, 220 for Slot.it, 250 for BRM and so far Avant Slot, but may try higher. Critical complete chassis is covered.
I leave in the oven for about 15minutes with heat on then switch off and allow to cool overnight.Alan Smith
