Avant AW gears
  • Avant AW gears
    Are there any replacement AW gears (e.g. Slot.it, NSR etc.) that work with Avant aluminum AW motor pods?
    I'm not sure on the gears,but I do know the aluminum mount is adjustable.
    Slot it gears should work.
    I can let you know for sure tomorrow.
      With the many different od gears from slot.it, nsr, and others, I am certain there is a combo that would work.
        Pretty much any 3/32 anglewinder spur gear will work with this pod,due to the adjustability.
        I tried Slot It,Nsr,Ninco,Scaleauto,Black Arrow,Sloting Plus,and a backwards angled MR Slotcar gear.
        They all worked fine with a Slot It 11 tooth pinion gear.
          Thanks SteeveeW
            What's wrong with the Avant slot AW gear? I have three Avant slot cars with that setup and all have the stock gear set.
