BRM BMW 2002 white kit arrival
  • BRM BMW 2002 white kit arrival
    The BMW arrived today of course nothing stays the same here. Sorry but I can’t leave things as is, I moved the wheels out about 1.2 mm each side on the rear with spacers The rears are near the edge of the fender. I also moved the the front wheels out 1mm each side also fitting flush. I like the independent front end but I will need to wait and see how it performs on the track as the front has a mild camber thing. No worrys, I already ordered and have the regular uprights. I will need to true the tires and balance the car as I go. I believe I can lower the car slightly with a tire change, cool thing is the Revoslot tires fit perfectly and has the potential to lower the chassis and provides chassis clearance of 1.2mm. I will need to mount the guide to determine if this is a good thing. I set the alignment of the rear and will pull the front to set the set the alignment and then start painting the body. I just need to find time to set up my track to find out if this thing is as good as the 1/32 cars.
    Heck, if you're going to do that much work on a car (and clearly, it's a worthwhile project), then you might as well enter it in a proxy race, or something ...
      Where’s the proxy, I’m in. Also we have a Under 2 liter proxy coming up in late 2022. If the 1/32 car is available I’ll run it. Hence all the crazy questions today so I will be competitive tomorrow. I’ve learned how to quiet the car, lower the weight and improve the handling with minor changes so far and will continue moving forward. But the word Proxy was mentioned so keep me posted even if it’s a 3 track run.... I will gather data for future use.
      porno
