Carrera Cheetah front tires
  • Carrera Cheetah front tires
    I have two Carrera Cheetahs that the front tires have turned to stone. I was wondering if anyone knows of a replacement?
    Thank you!!
    Maybe if you true them, that hard surface will be exactly what you want on those cars?
    Many racers spend time and money trying to achieve this.
      I will give that a try, hopefully it will quiet the cars down.. Thank you.
        No joy, when removing the stub axle assembly from the chassis the tires crumbled so new tires will be needed!
          Stub axles are the worse. The part number for the tires is 89770. Did a search and came up with nothing and I didn't see anything for Pg front tires. If you want to pay the shipping price Slot Car Union in France has them in stock.
            Thanks for the info Dave. I'll see if I can find something that fits If not I might have to order from France!!
            Tom
              Ours is an expensive hobby!….
                I made a mould for my Cheetah (and a heap of other Carrera cars) the tires either melt or go rock hard and crack - but usually they melt. I have sent you a message.
                cheers
                David
                  After a little searching of my cars I found that the Revell/Monogram Cobra Daytona rears fit.. I don't know if they are good enough for non mag they might need to be glued and trued. but with the magnets they are fine. Thanks for all the help!!
                    I just saw your post Dave, Thank you.. The ones I have should be good!!
