It looks like this hip can be used in cars beyond the Porsche/Audi Carrera says it fits; based on a forum search. I am planning to put it in a 2011 vintage Evolution and was trying to find a pinout for the lights, but many of the links in the sticky are broken. Any help/advice greatly appreciated.
Carrera 26733 Chip questions
If this is the chip shape you have then this is the wire setup. The grn/ylo is the front headlights and the tan/whi are the taillights. All the chips no matter the shape serve the same function. You can put the smaller 732 chip in there and do the same thing. The only thing that MAY be different is the LED placement. That's not an issue either as you just drill a hole in the chassis where the new LED meets the chassis. Finding the older chip that you have is difficult to find nowadays.
- Likes 1
https://i.imgur.com/9rC17C1.jpgOriginally posted by dw5555 View PostIf this is the chip shape you have then this is the wire setup. The grn/ylo is the front headlights and the tan/whi are the taillights. All the chips no matter the shape serve the same function. You can put the smaller 732 chip in there and do the same thing. The only thing that MAY be different is the LED placement. That's not an issue either as you just drill a hole in the chassis where the new LED meets the chassis. Finding the older chip that you have is difficult to find nowadays.
Question on lights - the Ferrari chassis has what looks to be holders for LEDs for the lights just above each wheel. Will 3 or 5 mm white LEDs work? 12 V In line resistor? If I can find teh right LEDs and plug I'll wire up my own light set.
That little square plug in the chassis is removable for digital chip installation. That's where the LED should be poking out. I believe the chip should be turned around so that the wider end is at the front of the car.
Live in the Seattle or Tacoma area? Check out these clubs!
Digital 1/32 (DRAWW)
Analog 1/32 (EMSA)
My Home Track ~ My Portable Track
My SCX WOS Experience ~ My Carrera Digital Experience
Digital Myths Busted! ~ INOX MX3 Rail Conditioner
Originally posted by MrFlippant View PostThat little square plug in the chassis is removable for digital chip installation. That's where the LED should be poking out. I believe the chip should be turned around so that the wider end is at the front of the car.
Originally posted by dw5555 View PostYes pull the light plug out of the chassis and run the lights through the chip. The lights through the chip however use 3V. 3mm should be a good size. I bought them in bulk off the bay years ago and still have about half left.
I'm ordering a bunch off of Amazon; will need to buy 20 or so more cars to convert...
DaveLast edited by jlc; 11-21-2022, 07:54 AM.
There is a polarity. The longer leg is usually the positive. To be honest, what it do a lot of the time is have the car on the track with the light wires plugged in to the chip and then just touch the lights to the wires on the plug. One way will light em up and the other won't. Won't burn anything up.
- Likes 1
Originally posted by dw5555 View PostThere is a polarity. The longer leg is usually the positive. To be honest, what it do a lot of the time is have the car on the track with the light wires plugged in to the chip and then just touch the lights to the wires on the plug. One way will light em up and the other won't. Won't burn anything up.
One other question - all the prewired LEDs appear to have a resistor in them - does that mater? I'd use prewired if possible to save some soldering.Last edited by jlc; 11-23-2022, 01:52 PM.
Originally posted by jlc View PostQuestion. Will the chips for hot rods work in other 1/32 cars?
Analog 1/32 (EMSA)
