Chipping the MR1003 Mazda 787B
  • Chipping the MR1003 Mazda 787B
    Ernie,
    This may seem to many as a dumb question. I currently have Carrera digital track and so far my arsenal of cars is limited to Carrera D132 and Scalextric that I have chipped for Carrera digital. I am very comfortable chipping Scalextric but I am now branching out to more "complex" cars and have a Slot.It on the way that I intend to chip and add lights. I think your MR1003 Mazda 787B [MR1003] is one of the most beautiful slot cars I've ever seen. Since I'm not familiar with the more "exotic" chassis' on the market, can you tell me if it's feasible to add a Carrera digital chip to your chassis? From photos I've seen, it looks to me like the "raised ribs" along the motor pod would prevent the chip from lying flat enough to the chassis pan for the LED to be effective. I would appreciate any advice you could you give me on this? Thanks!
    Originally posted by OldStrombeckerGuy View Post
    Ernie,
    Yes, I am thinking along the same lines, looking forward to your suggestions on this. By the way, my MRSlotcar Mazda 787B is currently using the stock inline mount, do you suggest changing to SW or AW configuration instead?
      longdog: Glad to see someone finally chimed in on this. Wish we could get a reply...
        Fingers crossed, we'll just keep pestering them!
          OK, got a couple of replies, so I have cut 'n paste them just as I received them, the Sure Change guide is the one where you can fit the LED straight into it.
          "Looking at images found on google, it appears to have a pretty shallow interior because of the inline configuration. As such, it shouldn't be hard to put just about any chip in there. I'd probably just put it at the front of the motor pod on a blob of blue-tack or hot glue. Using a SureChange™ guide will make the IR thing easier, if you're an SSD user. Use an F1 chip, since it's smaller and has the LED on leads already, plus the car has no lights to wire up anyway.
          You could probably get a Carrera chip in there if you needed to.
          But, I have not seen this specific car chipped yet. It looks like a combo between a slot.it can and an NSR or something. Shouldn't be hard to chip.
          I don't know much about the motor, though. If it's a hot one, then a slot.it chip might be the better choice for the higher power needs. Or, you can get an uprated Scalextric chip from GregK."
          Thanks to Mr Flippant for this reply
          These two beauties have been chipped but they have been converted to sidewinder using Mr Slot Car pods and Scaleauto slimline
          30k motor so there were no problems encountered.
          In your situation I would use a C7005 F1 chip and place it across the ribs such that it moves with the chassis. There is plenty of
          space underneath the driver."
          And thanks to GregK for the picture and reply on this one.
            Thanks lonedog! But I run Carrera Digital and will be using the 26732 chip because I want to attempt to add lights. (Sent you a PM).
            -Doug
