FC130 Inline Motor
  • FC130 Inline Motor
    The original FC130 MR Slotcar motor is rated at 22k. Did anyone do any real-world testing on this motor to see the real-life numbers? I'm currently thinking of organizing a race and want to compare this MR Slotcar motor with some other models that I have real-life numbers for. I would like to have similar motors allowed for this race, without limiting the choice to just one specific motor.
    Check out the Motor List at Slot Car News: http://slotcarnews.blogspot.com/2007...otor-list.html
      Thank you Dennis. I should have written that I did before posting. The MR Slotcar motor is not on that list, that's why I'm asking.
        My understanding is that there is more or less a gentleman's agreement amongst the manufacturers that their stock motors would be roughly equivalent. I'm thinking Sot.it, NSR, Scaleauto and MR Slotcar.
        You could always run a breakout race. Those can be fun.
          The on-track feeling is roughly the same for the two motors I want to allow in this race (MR Slotcar 22k FC130 and Piranha 21.5k). But I know some number-crunching guys will want to know the real-life numbers and I don't have those for them.
          By the way, the race would be an All-Canadian Proxy Race, for Canadian slotters, on Canadian tracks, with Canadian products. MR Slotcar Mazda 787B, CB Design wheels and Paul Gage tires. I'd like to allow the Piranha motor in addition to the stock MR Slotcar motor. That's why I'm asking.
            Allow the motor and allow people to use either irregardless what came with the car.
              Christian. I have a Laser Tachometer on order. As soon as it's in I'll test some Piranha and Mr SlotCar motors.
              Does any one have a good idea on how to make a some sort of disc that can be attached to a 2mm motor shaft? Any rubber adapters that work well?
              I'm thinking of using a set screw sidewinder gear and sleeving it down to 2mm, then painting a white stripe on disc. Any other idea's?
              Edit: I wonder if a simple white or black stripe on the bare motor shaft would be sufficient?
                Originally posted by Coquitlam Kid View Post
                ...I wonder if a simple white or black stripe on the bare motor shaft would be sufficient?
                Using a geometry set compass, I made a disc about 3 or 4 cm diameter out of card stock and coloured half of it black with a felt pen. I have a screw fit pinion that I can tape it to, but usually I just use a bit of masking tape to keep it on the motor shaft. Works fine.
                cheers
                Scott
                  ^ Thanks...usually the simplest things work the best. I'll give that a go.
                    If you have any Ninco Kart spur gears lying around, these fit onto the 2mm shafts.
                      Thanks, I'll put the word out to our Club members
