McLaren Front Suspension Kit
  • McLaren Front Suspension Kit
    Has anyone installed the front suspension on the McLaren F1? I just got the kit and it seems that the only way to get any "travel" of the suspension spring around the tall brass nut is to enlarge the hole in the front axle support where the brass nut goes through. The tall brass nut is a tight fit into the axle support hole and it seems to me that it needs to slide freely through the axle support hole so that the suspension can move up and down. Is my understanding correct? If not, what is the proper way to install the suspension?
    Thanks much,
    Thanks much,
    You are correct. Ernie said on his FB post that you may have to enlarge the holes slightly.
      Thanks Skyler - I appreciate the confirmation.
        Hi All
        Yes it's true -It was designed that way to keep tolerances to a minimum
        Ernie
