Just ordered my batch of Bosa tires. First order went on low rpm cars and worked great, really worked great with my Scaleauto Homeseries Viper non-magnet
2nd order of tires
Hundo, Here at TooBad Motorplex in addition to 1/32 cars we race the 1/24 BRM Porsche 962s with the OEM 30 shore rubber tires. The BOSA urethane tire's ability to grip does not seem to be affected by the rubber laid down from these heavier cars. I would expect your results to be similar.
Right now the only tires we have in 12mm width or wider are for Carrera cars. However we are continually adding new tires to our inventory. If you have a specific tire you would like reproduced and can send us a pair to mold, we will give you two pair of the urethanes molded from them and return your originals.
Sounds like a plan
Originally posted by wb0s View PostRight now the only tires we have in 12mm width or wider are for Carrera cars. However we are continually adding new tires to our inventory. If you have a specific tire you would like reproduced and can send us a pair to mold, we will give you two pair of the urethanes molded from them and return your originals.
