Tire truing rig
  • Tire truing rig
    Been a bit slow here so thought I'd throw up a couple of pix of the tire truing setup I assembled:
    Tire Razor in the upper right (bottom pic)
    Lower right is a sanding block reciprocator so I don't have to sit there manually running the block back and forth while the tires grind down. It's made up of a cheapy 200:1 5 Volt gear reduction motor with linkage made from scrap R/C car ball joints and a bicycle spoke.
    lower left is an the power supply. The base unit is an industrial regulated 12/5 Volt power supply. I salvaged about a dozen of these when the company I worked for upgraded to a system with much lower power requirements. I added a cover to keep kidlet fingers out, main and truer on/off switches, a PWM variable power adjustment for the truer motor, and a digital readout volt/amp display (unfortunately the amp meter part doesn't play nice with the PWM unit - must be a fairly large capacitor in that circuit as it just puts out a constant 12v when connected, so now it's just a nice bright on/off voltage display). The alligator clip connectors allow the supply to be used for motor break in duty as well.
    The plastic box at the upper left holds accessory parts. I cut up a couple feet of 1"x.25" aluminum bar stock and glued on wet/dry abrasive from 120 to 2000 grits to make a half dozen sanding blocks. Also made a pulley for 1/8" axles for those 1/24 Carrera cars.
    The whole thing sits in an aluminum tray recycled from the door of an electronics enclosure (from the company scrap bin for cosmetic defect - it'll have a lot more cosmetic damage as it goes to work ).
    cheers
    Scott
    You made my day with that one sir
    That is very cool
      GT6
      Real nice work, it's all in the details.
      You have great fringe benefits at your shop.
      bigman
        cheers
        Scott
        Any chance you can post the pics again?
