Love classic audio and the tracks.
My 1:32 Track Build
I'm totally impressed with this whole project. Gotta love the details, like the steps to the Dunlop bridge (probably some Fly trucks encouraged this, I'm guessing).
I have a pretty extensive music collection and have been listening to my CDs during the room build. My turntable is only in my main system. I have listened to all my progressive rock, classical, blues, jazz, oldies, new age discs and now rock discs in alphabetical order. I am now at Rick Wakeman. So almost done!
Update for 17 February 2020.
This track is set in the late 1960's so I am using hay bales rather than tires for lining barrier areas. I used 0.5 x 0.5 balsa wood cut to 1.0-inches long. Then painted with white glue and dredged in whole Thyme. Then sprayed with Testors Dull Coat clear to seal the Thyme. I just need to add baling wire to finish.
132 Build 027 by bonez 300, on Flickr
I am using Trackmate timing system with the dead-strip option. I had to modify my control stations to accommodate switching the dead-strip and track polarity simultaneously when changing direction. So I replaced the Double pole - Double throw (DPDT) direction switch with a Four pole - Double throw (4PDT) switch. I wired everything on my workbench and verified operation before installing on the track. Works great.
132 Build 026 by bonez 300, on Flickr
I finished the scratch built bleachers and placed them in two areas on the track. The areas will also feature television stands (bought in England). I am painting the cameras and operators now. The lights are functioning LED's from Woodland Scenics.
132 Build 028 by bonez 300, on Flickr
132 Build 029 by bonez 300, on Flickr
132 Build 030 by bonez 300, on Flickr
132 Build 031 by bonez 300, on Flickr
132 Build 032 by bonez 300, on Flickr
I installed two Miller Engineering animated billboards in two corners. They are designed to be installed on a building rooftop so I made cement foundations for placing in the dirt hillside. They really come alive when they are illuminated. I also have two rotating signs, also illuminated, that I will put near the pit building.
132 Build 033 by bonez 300, on Flickr
132 Build 034 by bonez 300, on Flickr
Overall views show it is finally coming together.
132 Build 037 by bonez 300, on Flickr
132 Build 038 by bonez 300, on Flickr
I am now working on the pit building and scene. It will have a lot of detail with figures and tools.
I am also up to Wishbone Ash on my music playlist. I am hoping to get thru my Yes collection before I am finished. ZZ Top may have to crank when I a finally get to running some laps - with a lot of bourbon and scotch!
- Likes 1
Originally posted by Pinto_Girl View PostThe whole thing looks really nice. Great job!
Track and car builds ?
Originally posted by B52RN View PostAnd the hay bales can double as snacks for your racer friends!
A truly awesome track...detail is amazing, thanks for sharing.
Nice to see you about again......
I think it was you and Pinto Girl were the two who consigned me to the bronze step on the podium in the Slot.it Shoot out a number of years back.
More progress - March 5, 2020:
Working on the pit scene. Still have to add more tools and figures. Figure bases will be trimmed and then figures glued in place.
132 Build 039 by bonez 300, on Flickr
132 Build 040 by bonez 300, on Flickr
132 Build 041 by bonez 300, on Flickr
132 Build 042 by bonez 300, on Flickr
Added PA speaker system to bleacher areas.
132 Build 043 by bonez 300, on Flickr
Completed power and control panel.
132 Build 044 by bonez 300, on Flickr
I went through my "Y" CD's and am now listening to ZZ Top. So almost done with track and my rock CD collection. Good timing.
April 2020 Status - Pretty Much Done
So I finally finished the 132 track. See photos below. The pit scene came out very well - lots of detail. I did finish the build listening to my last ZZ Top disc. Good timing. I now need to clean up the room, move tools back to cabinets in my garage, add more art work and track lighting. And a couch.
Kind of weird not having build tasks anymore. Looks like I will now start to play with everything. Took over four years from start to finish on the whole room. I do have about 300 plastic car models to assemble for the display cabinets.
132 Build 062 by bonez 300, on Flickr
132 Build 063 by bonez 300, on Flickr
132 Build 048 by bonez 300, on Flickr
132 Build 049 by bonez 300, on Flickr
132 Build 050 by bonez 300, on Flickr
132 Build 051 by bonez 300, on Flickr
132 Build 052 by bonez 300, on Flickr
132 Build 065 by bonez 300, on Flickr
132 Build 064 by bonez 300, on Flickr
132 Build 053 by bonez 300, on Flickr
132 Build 058 by bonez 300, on Flickr
132 Build 054 by bonez 300, on Flickr
132 Build 055 by bonez 300, on Flickr
132 Build 057 by bonez 300, on Flickr
132 Build 056 by bonez 300, on Flickr
132 Build 045 by bonez 300, on Flickr
132 Build 060 by bonez 300, on Flickr
132 Build 061 by bonez 300, on Flickr
- Likes 1
Originally posted by Bonez View Post,,,And a couch.
Also, your tracks are fantastic. I'm quite jealous of those who are fortunate enough to be your friend... never mind you. ;-)
Live in the Seattle or Tacoma area? Check out these clubs!
Digital 1/32 (DRAWW)
Analog 1/32 (EMSA)
My Home Track ~ My Portable Track
My SCX WOS Experience ~ My Carrera Digital Experience
Digital Myths Busted! ~ INOX MX3 Rail Conditioner
