So I finally bought a Thunder Slot and...oh my!
  • So I finally bought a Thunder Slot and...oh my!
    I bought the M6B No. 54 CanAm Mosport 1969. I had to go buy a T-6 Torx screwdriver to get the rear body screw out (all of the others I managed with other tools), so I was two+ days getting the digital chip installed.
    Just like the last slot.it classic I chipped (also a McLaren- the M8D), I didn't have to remove any of the interior. That's helped by the new smaller profile Carrera chips, and I also think the manufacturers are attempting to create as much space as possible between chassis and body.
    So this thing buttoned back up looking very nice. I had lowered the front tires so they would roll, and loosened the body and suspension screws just a turn or so to give some float. I run only silicone tires, so I swapped the originals for a set of Quickslicks and ran a couple of laps. After a few laps getting the feel of the car, I was running 9.8 and 9.7- very respectable for a no-mag car on my track. I ran the tires over my sanding pad for a bit and was then turning 9.4 and 9.3- which is getting down close to the top 5 cars on my track.
    Then I dialed back the brake, as a new chip will have the brakes on full. Tried 10/16, and that wasn't quite enough brake. The car wasn't slowing quickly enough on the long straights on my track. So then 12/16 and WOW!! we found the sweet spot. The car slowed on the long straights, but still carried some speed into tight corners.
    Within three or four laps I broke 9 seconds (only the second no-mag car to do so on my track), and then with some concentration I turned an 8.826. That's about .150s faster than the previous no-mag record on my track!
    The car is just so easy to drive fast it's ridiculous! Planted doesn't even begin to describe it.
    It's really pretty and really fast and I think it will definitely not be my last Thunder Slot. I'll need at least two more just to have some running mates!
    Any pics of the chip install?
      Welcome to the club. When I was considering entering the 2020 CanAm Proxy I said can I make my Monogram Lola competitive? No way I bit the bullet and got me a TSlot. Best decisions I could have made. Now do I buy more??? Since I race home alone I really don't need but 1 maybe 2. So maybe an order is due soon. An Elva maybe????
        I had heard the hype on these for years and was prepared to be mildly disappointed. The hype didn't do this thing justice. I remember buying my first slot.it- what an eye opener that was for someone who owned only Carrera. Then I bought an NSR Mosler to run in an analog club. Another OOTB stunner. Never thought I would have a similar experience, but this thing with literally zero tuning is the best car I've ever owned.
        I have a large selection of slot.it classics chipped for my Carrera track. So I will now be buying more Thunder Slots, as the slot.its stand no chance (I know guys who could make them competitive- but it isn't happening with my limited abilities)
          No. But I can tell you I enlarged the chassis screw hole that mounts this car to it's case, as that was a perfect spot for the direction switch on the chip (I only enlarged the hole enough so I can flip the switch back and forth with a small blade screwdriver. Not so much that I could put my fingers on the switch- it just isn't necessary). The location for the LED was dictated by this decision. It fell just outside the motor pod. Other than that the only modification was gluing a small bit of plastic (a piece of a very narrow wire tie) to the top rail of the motor pod to keep the LED from protruding below the chassis. A little hot glue to hold the chip in place on the pod and solder the wires.
            I got one recently as well. It's a great car, to be sure. Fits right in with (other) NSR cars. I believe Thunderslot is under the control of a former NSR guy.
              ...I believe Thunderslot is under the control of a former NSR guy.
              Correct. The Italian slot car companies are just about as intermingled and competitive as early Detroit .
                The Lola is on my list to buy so glad to hear you’ve had a good experience with your TS.
                  My sentiments exactly!
                  I like the look of the Elva's.
                    Sounds amazing, what style of chassis is it? Plastic with triangular shaped pod?
                      Very flexible lightweight plastic and a large triangular motor pod. This particular model has a sidewinder setup (with the motor slightly canted, not directly parallel to the axle). A wonderful front axle suspension adjustment with set screws above and below the axle to allow for very fine tuning of wheel contact. I *think* all of that is typical for the brand.
                        pics are worth a thousand words!
                          The Lola was my first purchase on return to slot cars, it set a very high benchmark. As well as the well placed handling they are very light and get the maximum out of the motor. Mine. Now features a shark 25 which really lights the car up on bigger tracks.
                            This is one of my favorite Thunderslots, the M6 is another one that I enjoy also.
                              I just bought 3 Thunderslots myself and had a similar reaction to the author, b.yingling. I opened one up to find I too needed a T6 driver tip.So no chip install yet.
                              Thunderslot CA00204 Lola T70 Spyder - '67 Mosport Park, Thunderslot CA00302 McLaren M6A - '68 Laguna Seca, and Thunderslot CA00403 McLaren Elva M1A - Driven by Elvis Presley. They are beautiful and I hope they are all they are supposed to be.
