replacement tires for Scalextric Audi R8
  • replacement tires for Scalextric Audi R8
    We are wanting to try some slot.it tires for our Scalextric Audi R8 cars. What size (including part no.) fits this car best? We are considering the P6 and P2 compounds for our Scalextric Sport Digital track. Does this sound like a good idea?
    Chances are the Slot.It tires will not fit onto the stock Scalextric wheels.
    If you are really wanting to run Slot.It (or NSR) rubber, you'll most likely have to replace the stock wheels with aftermarket wheels designed to take Slot.It tires. This means you most likely also have to replace the rear axle, bushings and gear as well, because the aftermarket wheels are not designed to fit stock Sclaextric axles.
      super tire 1100 or 1105, both will work fine.
        super tire 1100 or 1105, both will work and no added expense for other parts.
          You can also use Maxxtrac M45's. They work very well on the Scalextric track and look good with the rounded edge.
            Thanks for all the suggestions, guys. They are appreciated. We have also been digging in to how to figure out what wheels and tires will fit what. Very confusing topic. There has been quite a bit of useful information in older posts on the forum, and we have been going back through it.
            Jesse
              There are a number of aftermarket wheels that mimic Slot.it wheels, including Superwheels and some of the CB Design wheels from Slot Car Corner. Besides the Slot.it tires there are Supertires, Yellow Dogs and Indy Grips/MaxxTraxx that fit those wheels. There are fitment tables on both the Professor Motor and Slot Car Corner sites.
