motor question
  • motor question
    Is it possible to replace the motor in my parma flexi chassis, D16, with say a 18000 to 25000 motor. The reason is the Parma motors pull a lot of amps. I would like to be able to put a motor in so I can run my old cars on the nearby track and not have power concerns for them. I'm a NOOB to the 1/32 scale stuff. The nearest 1/24 King track is almost 40 miles away. So I don't want to put my 1/24 stuff away. Just want to have fun with them if possible. Thanks in advance, CB
    CB,
    A Parma "Homeset" will work. Also a JK Retro 25 will work.
      thanks
      Thank you very much!!!!! I love the short and sweet answer!!! REALLY not kidding. Will give it a try. I have a couple places I can check on those motors nearby. If not I'm sure online I can grab some!! Thanks again. CB
        Google "PCH Parts Express".
          As fl_slotter says, a Parma Homeset 16d is a good choice, it's a lower power version of the 16d those Parma chassis are designed for so it'll screw straight in.
          There are plenty of other options, although fixing them in is slightly more difficult.
          Flex type chassis are frequently used with FF-130 / FK-130 size motors. There's a vast choice of specs available from many suppliers,for example the JK Hawk 25 and JK Hawk Retro, many Ninco and Scale Auto motors. Mostly they are soldered in as the screw hole pattern doesn't match the Parma bracket.
          S can motors are another option, again a vast choice of motors intended for plastic chassis type cars - as long as they have a sufficiently long shaft at the can end they will fit. Again the screw hole pattern doesn't match the Parma bracket on most of them, but soldering the can in is no problem or extra holes could be drilled in the can.
            Thank you both for some good ideas. I appreciate it!!!! CB
