Having removed some armatures from the gearplate to tweek /replace, I realized that the gear didn’t fit titely enough...
tried using a beebee and a hammer to peen the brass motor gear holes. Worked rather well.
however when i tried to do the same on the drive pinion gear, the gear cracked...
i had both new pinion gears and shafts, but they initially came loose after installing in the chassis and powering up to speed.
hence the attempt to peen the gear to fit..
(super glue is not an option)
any good options for getting pinion gears ready for installation on a shaft?
