Hi Guys,
I have the need to check out samples of new axles I am having made and while I was at it I decided I would also test out a Dash 4 lam armature I bought quite a while back along with using plastic armature and idler gears. After assembling the chassis using an old Aurora bare tub and top plate, and adjusting the height of the armature I got the car running.
Because the 4 lam armature will Ohm at around 5 it required the (almost) strongest magnets I have. This makes the gear train pretty tight because it takes more force to turn an arm paired with strong magnets. After a number of laps the arm gear lost it's grip on the armature and any subsequent reinstall only lasted a while before getting loose again. I eventually installed a metal arm gear so I could continue testing.
I figure the plastic gear let loose due to two reasons. (1) I needed to reinstall the arm at least twice to get the proper height so the arm would contact the brushes and (2) there is a lot of torque on the gears because of the strong magnets.
I did not try a second arm gear nor did I try to "preen" the plastic gear (if that is even possible).
So here is my question...how has everyone else fared with using the plastic armature gears? Should they only be used with standard 15-16 Ohm armatures and stock strength magnets? Do the lower Ohm armatures and strong magnets over-match the grip strength of the plastic gear?
Thanks...Joe
Thanks...Joe
