All I think I have left of a playing mantis is a top plate with rear gear set:
notice the size of the pinion gear: (same 14-tooth as the drive gear)
brass and delrin are shown for comparison…
Removed the gear to create a cannibal car…
note that the shaft was splined on the drive gear side
mite try the splined shaft with a new delrin drive gear and remove the playing mantis pinion to install from the top.
then it mite be a bit tricky to add a pinion gear (especially a 9-tooth pinion) .
l do have a hammer and cutting board.
or if I use the 14-tooth delrin as the pinion, I guess I could try my wheel puller to “pull” it onto the shaft.
another option that may be easier to do would be to “hammer”/press fit the spline end of the shaft into the pinion gear and press fit thru the gear plate into the rear gear.
of course the the shaft would extend above the top plate gear
shaving down the crown gear to mesh with a 14-tooth pinion is another project….
