Hi Ed, sent you a PM so I can order some slide guides for old TYCOPRO cars. (By the way, your tables are gorgeous and the cats meow.)
As for my testing and experimentation:
Here is the current iteration. The tape is wide and flat and supports HO cars with stock silver colored shoes. I lay the tape in a shingled fashion so the car cannot peel the tape going around the track. Tape with conductive adhesive is a must for this set up, imho. Easy to lay down. Only trim after making a bunch of laps. The cars tell you where to slice with an xacto.
Whatcha think? Btw, the wires will be attached via a counter sunk brass screw to the underside via a routed channel to the edge and not via wings.
I found that there cars with plated hard shoes go very well. Pure copper shoes go better on the aluminum tape track. So there is something to the dissimilar metal theory.
I did have to go over the copper tape with very fine 1000 sandpaper (a little bit). Unfortunately this tape is only 0.7 mil (amazon ad lied, said it was 2.5 mil), so if the scouring is needed frequently then the tape may wear out?
But I need to do more exhausting testing. Hard shoes require the wide tape so they don't get beached on the wood.
