Arduino rally lap timer?
  • Arduino rally lap timer?
    I have built this lap timer https://www.youtube.com/watch?v=m1XpbHmVyQ0&t=44s
    and modified it for single rally track it works great. But I would like to make it turn the power off after 5 laps I know I would need to use a relay but how would I wire it up and what would I need to add to the arduino code.
    So what I want to do is press the start button wait for the countdown lights to go out and the race to start you drive 5 laps and then the power go's of then you can press the start button again and it starts again.
    Have attached zip file with code and schematic in it. I am only using one sensor as it is for rally track
    Suggestion
    Contact us at [email protected]
    Maybe we can help ??
      Well I have it all working as I want it to.
      and if anyone wants to see it here is the complete code.
      Code:
      /* Slotcar Race Lights with Laptimer/counter v0.6
       Author: Rotzbouf
       Date: 12/05/17
       Description:
        * Complete Code rewritten in v0.5
          * Interrupt Routines are now as short as possible and only save the timestamp of activation
        * When the Board is started up, it will show "READY!" in LCD
        * The starting phase will be initiated by pressing the START_RACE button. (Pin 48)
          * When start phase is initiated, "SET!" will be visible on LCD
          * Inverval between each LED is set random between 1s and 3s.
          * When lights turn to green, "GO!" will be visible on LCD
        * Timing functions are called via Interrupts (Pin 2 and Pin 3 on the Arduino)
        * Bestlap is recorded per lane and overall
        * Lapcount (L), Laptime (T), Besttime (B) is shown per lane on LCD
        * Best overall lap is visible on LCD
        * Stores Best overall laptime in EEPROM to save time on reboot/poweroff
        * Clear EEPROM memory by pressing RESET Button. (Pin 41)
          * A message will be displayed on LCD when clearing EEPROM.
        * Both pushbuttons (BTN_START_RACE and BTN_RESET_TR) are debounced
          * No delay() used to ensure that interrupts are recorded correctly
        * Race Start Sequence rewritten to remove delay(), this will ensure propper interrupt timings
        * Early Start Detection shows a message on LCD
      #include <LiquidCrystal.h>
      #include <EEPROM.h>
      #include "EEPROMAnything.h"
      // Relay pins
      const int RELAY_PIN = 9;   // connect to IN1 on relay
      // Starting Light Pins
      const int LED_GREEN = 53;
      const int LED_YEL = 52;
      const int LED_RED = 51;
      // Button and Timer Pins
      const int BTN_START_RACE = 50;
      const int BTN_RESET_TR = 49; // BTN to clear EEPROM
      const int TIMER_SLOT_1 = 2; // Pin 2 = Interrupt 0
      // LCD Pin Setup
      LiquidCrystal LCD(12, 11, 7, 6, 5, 4);
      // Variables for Timer
      float LAPTIME_SLOT1 = 99;
      float BESTLAP_SLOT1 = 99;
      float BESTLAP_ALL = 99;
      unsigned long START_RACE_TIME = 999999;
      unsigned long STORE_OLD_TIME_SLOT1 = 0;
      unsigned long STORE_NEW_TIME_SLOT1 = 0;
      // Variables to save temporary values used by ISRs
      volatile unsigned long GET_LAPTIME1_TIME;
      volatile unsigned long GET_LAPTIME2_TIME;
      volatile boolean PROCESS_TIME1 = false;
      volatile boolean PROCESS_TIME2 = false;
      // Lapcounter
      int LAPCOUNT_SLOT1 = 0;
      // MISC Variables
      float TR_OLD = 99; // Variable to store Track Record from EEPROM
      boolean EARLY_START = false;
      // BTN Debounce Variables
      unsigned long BTN_START_DEBOUNCE_TIME = 0;
      unsigned long BTN_RESET_DEBOUNCE_TIME = 0;
      unsigned long BTN_DEBOUNCE_DELAY = 100;
      int BTN_START_CURRENT;
      int BTN_START_STATE;
      int BTN_START_LAST_STATE = HIGH;
      int BTN_RESET_CURRENT;
      int BTN_RESET_STATE;
      int BTN_RESET_LAST_STATE = HIGH;
      // Start Race Sequence Variables
      unsigned long START_RACE_CURRENT_MILLIS;
      unsigned long START_RACE_PREV_MILLIS = 0;
      int RAND = 0;
      boolean RACE_STARTED = false;
      // Pin Setup
      void setup() {
       pinMode(RELAY_PIN,OUTPUT);
       digitalWrite(RELAY_PIN, HIGH); // turn off the relay
      pinMode(LED_RED, OUTPUT);
      pinMode(LED_YEL, OUTPUT);
      pinMode(LED_GREEN, OUTPUT);
      pinMode(BTN_START_RACE, INPUT_PULLUP);
      pinMode(BTN_RESET_TR, INPUT_PULLUP);
      pinMode(TIMER_SLOT_1, INPUT);
      attachInterrupt(0, GET_LAPTIME1, FALLING);
      LCD.begin(20, 4);
      LCD.clear();
      LCD.setCursor(7, 2);
      LCD.print("READY!");
      Serial.begin(9600); // remove in final code
      void GET_LAPTIME1 () {
      GET_LAPTIME1_TIME = micros();
      PROCESS_TIME1 = true;
      void loop() {
      // Debounce BTN_START_RACE
      BTN_START_CURRENT = digitalRead(BTN_START_RACE);
      if (BTN_START_CURRENT != BTN_START_LAST_STATE){
      BTN_START_DEBOUNCE_TIME = millis();
      if ((millis() - BTN_START_DEBOUNCE_TIME) > BTN_DEBOUNCE_DELAY) {
      if (BTN_START_CURRENT != BTN_START_STATE) {
      BTN_START_STATE = BTN_START_CURRENT;
      if (BTN_START_STATE == LOW) {
      RACE_STARTED = false; // Set value to false when button is pushed
      RAND = random(1000,3000);
      START_RACE_CURRENT_MILLIS = millis();
      START_RACE_PREV_MILLIS = START_RACE_CURRENT_MILLIS;
      LCD.clear();
      LCD.setCursor(8, 2);
      LCD.print("SET!");
      while (RACE_STARTED == false) {
      if (START_RACE_CURRENT_MILLIS >= START_RACE_PREV_MILLIS + RAND && digitalRead(LED_RED) == LOW && digitalRead(LED_YEL) == LOW && digitalRead(LED_GREEN) == LOW) {
      digitalWrite(LED_RED, HIGH);
      if (START_RACE_CURRENT_MILLIS >= START_RACE_PREV_MILLIS + RAND && digitalRead(LED_RED) == HIGH && digitalRead(LED_YEL) == LOW && digitalRead(LED_GREEN) == LOW) {
      digitalWrite(LED_YEL, HIGH);
      if (START_RACE_CURRENT_MILLIS >= START_RACE_PREV_MILLIS + RAND && digitalRead(LED_RED) == HIGH && digitalRead(LED_YEL) == HIGH && digitalRead(LED_GREEN) == LOW) {
      digitalWrite(LED_RED, LOW);
      if (START_RACE_CURRENT_MILLIS >= START_RACE_PREV_MILLIS + RAND && digitalRead(LED_RED) == LOW && digitalRead(LED_YEL) == HIGH && digitalRead(LED_GREEN) == LOW) {
      digitalWrite(LED_YEL, LOW);
      LCD.clear();
      LCD.setCursor(9, 2);
      LCD.print("Go!");
      digitalWrite(LED_GREEN, HIGH);
      LAPCOUNT_SLOT1 = 0;
      START_RACE_TIME = millis();
      LAPTIME_SLOT1 = 99;
      BESTLAP_SLOT1 = 99;
      BESTLAP_ALL = 99;
      digitalWrite(RELAY_PIN, LOW); // turn on the relay
      if (START_RACE_CURRENT_MILLIS >= START_RACE_PREV_MILLIS + RAND && digitalRead(LED_RED) == LOW && digitalRead(LED_YEL) == LOW && digitalRead(LED_GREEN) == HIGH) {
      digitalWrite(LED_GREEN, LOW);
      RACE_STARTED = true;
      BTN_START_LAST_STATE = BTN_START_CURRENT;
      // Debounce BTN_RESET_TR
      BTN_RESET_CURRENT = digitalRead(BTN_RESET_TR);
      if (BTN_RESET_CURRENT != BTN_RESET_LAST_STATE){
      BTN_RESET_DEBOUNCE_TIME = millis();
      if ((millis() - BTN_RESET_DEBOUNCE_TIME) > BTN_DEBOUNCE_DELAY) {
      if (BTN_RESET_CURRENT != BTN_RESET_STATE) {
      BTN_RESET_STATE = BTN_RESET_CURRENT;
      if (BTN_RESET_STATE == LOW) {
      CLEAR_EEPROM(); // Call function to clear EEPROM
      BTN_RESET_LAST_STATE = BTN_RESET_CURRENT;
      if (PROCESS_TIME1 == true) {
      GET_LAPTIME1_TIME = GET_LAPTIME1_TIME / 1000;
      if (GET_LAPTIME1_TIME < START_RACE_TIME) {
      EARLY_START = true;
      else {
      CALCULATE_LAPTIME1();
      if (PROCESS_TIME2 == true) {
      GET_LAPTIME2_TIME = GET_LAPTIME2_TIME / 1000;
      if (GET_LAPTIME2_TIME < START_RACE_TIME) {
      EARLY_START = true;
      else {
      CALCULATE_LAPTIME2();
      if (EARLY_START == true) {
      // Early Start Detected
      LCD.clear();
      LCD.setCursor(5, 0);
      LCD.print("Early Start");
      LCD.setCursor(6, 1);
      LCD.print("detected");
      LCD.setCursor(2, 3);
      LCD.print("Restart the Race");
      void CALCULATE_LAPTIME1() {
      STORE_NEW_TIME_SLOT1 = GET_LAPTIME1_TIME;
      if (LAPCOUNT_SLOT1 == 0) {
      STORE_OLD_TIME_SLOT1 = START_RACE_TIME;
      LAPTIME_SLOT1 = STORE_NEW_TIME_SLOT1 - STORE_OLD_TIME_SLOT1;
      LAPTIME_SLOT1 = LAPTIME_SLOT1 / 1000;
      STORE_OLD_TIME_SLOT1 = STORE_NEW_TIME_SLOT1;
      if (LAPTIME_SLOT1 > 1) {
      LAPCOUNT_SLOT1 = LAPCOUNT_SLOT1 + 1;
      if (LAPCOUNT_SLOT1 > 5) {digitalWrite(RELAY_PIN, HIGH);} // turn off the relay *****************************************************
      if (BESTLAP_SLOT1 > LAPTIME_SLOT1) {
      BESTLAP_SLOT1 = LAPTIME_SLOT1;
      if (BESTLAP_ALL > BESTLAP_SLOT1) {
      BESTLAP_ALL = BESTLAP_SLOT1;
      UPDATE_TR();
      LCDPrint();
      void CALCULATE_LAPTIME2() {
      UPDATE_TR();
      LCDPrint();
      void LCDPrint() {
      LCD.clear();
      LCD.setCursor(6, 0);
      LCD.print("L: ");
      LCD.print(LAPCOUNT_SLOT1);
      LCD.print("T: ");
      LCD.print(LAPTIME_SLOT1,3);
      LCD.setCursor(6, 2);
      LCD.print("B: ");
      LCD.print(BESTLAP_SLOT1,3);
      LCD.setCursor(0, 3);
      LCD.print("Track Record: ");
      LCD.print(BESTLAP_ALL,3);
      void UPDATE_TR() {
      EEPROM_readAnything(0, TR_OLD); // Read saved data from EEPROM
      if (TR_OLD < 1) {
      TR_OLD = 99; // if time is lower than 1s, set Record to 99s
      if (BESTLAP_ALL < TR_OLD){
      EEPROM_writeAnything(0, BESTLAP_ALL); // Write new Track record to EEPROM
      else {
      BESTLAP_ALL = TR_OLD;
      void CLEAR_EEPROM(){
      LCD.clear();
      LCD.setCursor(4, 1);
      LCD.print("Clearing");
      LCD.setCursor(4, 2);
      LCD.print("EEPROM");
      for (int I = 0 ; I < sizeof(BESTLAP_ALL) ; I++) {
      EEPROM.write(I, 0);
      LCD.print(" done");
      and here is the wiring diagram
        Code:
         Author: Rotzbouf
         Date: 12/05/17
         Description:
        #include <EEPROM.h>
        // Relay pins
        // LCD Pin Setup
        // Lapcounter
        // MISC Variables
        int RAND = 0;
        // Pin Setup
        void setup() {
        LCD.begin(20, 4);
        LCD.clear();
        void loop() {
        LCD.clear();
        LCD.print("SET!");
        LCD.clear();
        LCD.print("Go!");
        LAPCOUNT_SLOT1 = 0;
        LAPTIME_SLOT1 = 99;
        BESTLAP_SLOT1 = 99;
        BESTLAP_ALL = 99;
        EARLY_START = true;
        else {
        EARLY_START = true;
        else {
        LCD.clear();
        UPDATE_TR();
        LCDPrint();
        UPDATE_TR();
        LCDPrint();
        void LCDPrint() {
        LCD.clear();
        LCD.print("L: ");
        LCD.print("T: ");
        LCD.print("B: ");
        void UPDATE_TR() {
        if (TR_OLD < 1) {
        else {
        LCD.clear();
        EEPROM.write(I, 0);
        LCD.print(" done");
        The wiring diagram is missing?
          Hey Quakebo - This is fantastic! I am thinking of setting up a routed wood rally track, and using something very similar.
          One thing that I would like to add is a bright LED flash when the new lap record is set, and add it into the scenery like a fixed speed camera - Do you have any advice on how I would go about that? I would imagine getting a flash bright enough from an LED would be tricky - but if my iphone can do it, I am sure an arduino can, too.
