Gone Racing
What I learned from the build was:
1. It's no use lightening the chassis too much by using lighter materials (e.g. PCB or for that matter aluminum, plastic card or popcicle sticks) if the CG ends up too high.
2. It's better to use heavier materials (brass wire or plate, steel wire or plate) where strength is needed but as low as possible to keep CG low.
3. A rough calculation holds if the chassis does not slide:
Lateral G force at tipping = weight of car x half width / height of CG
If you do this check it is amazing how much effect low CG and car width have. Once it slides this no longer holds true.
4. Some twisting flexibility also seems to improve the handling.
irco
irco
