Next Series , Revo Slot GT2's
  • Next Series , Revo Slot GT2's
    NEXT SERIES REVO SLOT GT2'S
    MANDATORY
    BRAND - Revo Slot
    TYPE - Porsche GT2 , Marcos LM 600 GT2 , Dodge Viper and Toyota Supra
    MIN WEIGHT - 96 gms , MAX DOWN FORCE - 5 gms
    SCREWS - Stock , loose or tight
    TIRES - Fronts , stock - Rear RS- 202S Shore 22 Soft ( both may be glued and trued )
    MODIFICATIONS
    ADDED WEIGHT - Up to 5 gm anywhere in side car
    CHASSIS - Stock to car
    GEARING - Stock 12th pin or plastic 12th pin - 33th Anglewinder crown
    GUIDES - RS 210 - 7mm , RS 210W - 9mm
    INTERIORS - Stock
    MOTOR - Stock , RS211 - 21 k
    POD - Stock to car
    WHEELS - Stock , Front RS 108 , Rear RS 109
    WIRING - Stock
    MISCELLANEOUS - Hard low profile fronts may be used , Really not much else to change , about as stock as you can get
    Any questions , concerns or idea's let me know .
    Addition to REVO spec's
    FRONT TIRES - RS 201 Hard low profile may be used
      This will be our next series, so I'm bumping the thread. I believe we're going to allow plastic pinions in addition to adding the Marcos, Viper, and Supra to the mix. Otherwise, specs are the same.
