Winter Series Introduction, Race Fees & Rules
  • Winter Series Introduction, Race Fees & Rules
    Hello All,
    Welcome to the second season of the GT-SRC: “Greater Toronto - Slotcar Racing Club”. Our goal is to provide affordable, competitive, and fair racing in a club environment. This season we will be running a weekly series at Race Haven Hobbies, which is located in Brampton Ontario, Canada.
    Charter GT-SRC members include Grant Richardson (Treasurer), Sean McQuade (President & Communications), Franco DeVuono (Chief Tech Inspector) and Serge Tourikian (Tech Inspector)
    There will be a club fee of $20 per series paid to GT-SRC Treasurer per race series.
    Race Fee
    $10 per race. $5 dollars from each entrance fee will be paid out in 'Race Bucks'.
    See payout schedule below in the attachments section.
    As usual we will award Racebucks every race night. Our racebucks are randomly awarded ‘by drawing names out of a hat at the end of each race. At the end of each season trophies will be awarded out to the top three places. Participation Plaques with your name and series/date in addition to “dash plaques” for your tool/car boxes will be handed out at the end of each season.
    Spec Car - The GTSRC has chosen to continue using the 'Stock' Slot.it 956 / 962 Porsche as the spec car for our second series (including the 956K high tail 'Jagermeister'). Inline slot it pod - can side only (no offset pods)
    • Slot.it 9 tooth bronze pinion - Slot.it 28 tooth Slot it Crown gear - bronze only (no Teflon)
    • 15x8 Slot it aluminum rear wheels (Ortmann tires)
    • Plastic Slot it 'stock ' front wheels and Slot it tires
    • Slot it wheel inserts must be used (no drilling out centre of insert)
    • Press in 'Stock Guide' (any braid can be used)
    • Solid Slot it 'Stock' or Drill Blank axles
    • Slot it 21.5k orange bell or Slot it 25k white bell (with 'Stock' Slot it lead wire)
    Rules - Cars will be teched by GT-SRC Members only.
    All tech will be done and enforced by GT-SRC Members only. Cars that do not pass tech will be allowed to race but will not be able to receive points for the series Nor be eligible to participate in the draw for 'Racebucks'.
    Cars that are questionable will be allowed to race but will be warned to change the items In question. If the items have not been resolved the following race, the racer will allowed to race but will not be able to receive points for the series Nor be eligible to participate in the draw for 'Racebucks'.
    • Stock Magnets are allowed but must remain in the designated magnet holding area.
    • Magnets must not touch the motor
    • Rear Tires will be no wider than 11mm and no taller than 19.5mm
    • Tires can be glued to rim
    • Cars must have a clearance of .047 on 'block' (this rule may be changed to allow for tire wear)
    • Front tires must touch on a flat tech 'block'
    • Front tires must be untreated (no nail polish, ca glue, ect.)
    • Front tires must be as wide as plastic rims
    • Front tires can be sanded
    • Wheels/tires must not be visible when viewed from above
    • No coating of any kind on the front and rear tires ie: (no nail polish, ca glue, ect.)
    • No chassis reinforcements are allowed
    • Lead can be added (no weight on underside of chassis)
    • Original motor wire leads must be used. Slot.it red silicone lead wires.
    • Motor shaft must act as centering guide for Crown
    • Motor shaft can be trimmed on can side only
    • Motors must be “unopened”- any evidence of tampering will result in disqualification
    • Motors may be glued / taped into chassis
    • Motor sealing tabs must remain clearly visible
    • No axle spacers or shims are allowed
    • No Aftermarket bushings or bearings may be used
    • Tires cleaned with water or spit only
    • No com juice, braid juice, or lighter fluid
    • Rear wing must be on car
    • Minor sanding of the four sides of chassis for body clearance is acceptable
    • No sanding under or inside of chassis in the attempts of reducing weight
    • Stock body and interior - Painting is allowed - Cars will compete with original chassis/body combination. Bodies may not be lightened
    • Lexan interiors/windows will not be allowed
    • All cars must have 4 stock Slot-it wheel inserts.
    Sean McQuade
    GT-SRC
    Greater Toronto Slotcar Racing Club
