Looking for a new power source
  • Looking for a new power source
    I have a 78' 4 lane Scalextric track that is running off a Pyramid Adjustable power supply. I need more power but would also like to keep it a variable power supply. There are a lot of bench top power supplies out there in the wild. I would like to know what other folks use.
    -Vince
    Not variable...but I switched to (lead acid) battery (small tractor) power a few years back and will never go back to a store bought power supply.
    Also, a battery has more than enough amperage in store for the wildest motors in all four lanes.
      How would you run Carrera cars then since they require 14.8V? Normal Ninco/Scalextric run at 12V
        Hi Vince
        A lack of power is quite often due to inadequate wiring / poor continuity between track sections. If that's the cause of the problem, a higher current power supply won't help.
        How much power you need depends on the motors you use. You'll get better advice on what to buy if you can give some more information on what you use and what sort of Pyramid power supply you have
          Originally posted by Al's slotracing View Post
          Hi Vince
          My MFJ-4035MV maxes out at 13.8 V. Carrera need 14.8V. I have no issues running Slot-it, Scalextric, or Ninco at 12V. Carrera as 12V is unraceably slow.
            Take out the magnuts. ;-)
              Thanks for that
              For the cars you've mentioned, the current from your existing supply is overkill.
              A unit that's widely used for slot car tracks in the USA (and other countries with a similar mains supply voltage) is the Pyramid PS26KX 22 Amp Power Supply - that's adjustable up to 15 volts.
              You can spend more money to get more amps, but unless you are wanting to use higher current motors there's no point in spending more.
                I have that Pyramid 22 amp power supply as well, I mostly use it to power up a tire truing machine. The Pyramid is a linear power supply, those need a large expensive transformer. My track is powered by Mastech switch mode power supplies and those are lighter and cheaper than linear supplies. The Mastechs that I use are 0-30 volts, 20 amps. A 10 amp power supply should be enough for any motor that is used with home style 1/32nd cars. If your cars would be powered by commercial raceway 16D type motors you would need a lot more power.
                  I was wondering if a Carrera power supply actually put out 14.8 volts with a couple of cars running. The nameplate voltage does not mean a lot if a power supply is not regulated. In any case a 10 amp 0-18 volt power supply would do the trick. Here is one: http://mastechpowersupply.com/20v-10...lications.html
                  If you search the net you can find a similar unit for quite a bit less.
                    All the Cincy guys use the MG Power supply. 5+ years, so far so good.
                    Bruce
                      The MG is a great choice. Here is an article hot off of the presses! Comments would be welcome.
                      https://drive.google.com/file/d/118M...ew?usp=sharing
                      porno
