I have a third eye predator 2 - 3000mp Gawronski edition controller with no fans. Will I be able to run G12 cars or will it get to hot. I will be only running two heats that are 15min long and there will be other heats between mine so the controller will get to cooldown between my heats.
If I need to fit two 40mm fans how would I wire them into the controller.
Also what size and type of bearing do I need for the trigger as mine is very worn after 13 years of use and could do with replacing.
