Why do none of my track load anymore?
  • Why do none of my track load anymore?
    I have not been using my slot cars for a while, maybe 20 months. I plan on setting them up again. I attempted, multiple times, on more than one computer, to bring up my layouts in UR30 and they no longer load!! What gives? Any help would be appreciated, I'm using UR 3.024. I get an error on all tracks saying "unexpected file format".
    Regards,
    Ted
    Hi Ted,
    can you send couple of files to support@uracer.org?
    What was your previous release?
    Rgds,
    Pierrick
      I think this is the same version I last used, don't think I updated. Let me check my other computer as well. My kids are on it now, will check it later. I might have loaded a newer version on this one at one time, but I know the files don't load on either. I'll send you a couple of sample files.
      Regards,
      Ted
        file received.
        It works when you start UR30 first, then open the files from the file menu.
        It crashes when clicking twice on a file icon (new compiler library hidden behaviour???).
        Under (urgent) investigation.
          All files can be opened from file->open menu & by clicking twice on them.
          I am using Windows 8 64bits. I am strongly suspecting a bug in the VS 2012 MFC static libs, or a missing Visual Studio patch.
          I did have to patch my box already once as VS static libs were not working properly on Windows XP (!!!!!)
            to close this thread:
            I figured out the problem(s) on both computers. Apparently when I installed new versions, the old versions didn't get fully un-installed, even when I tried to re-install again. I cleaned both computers by doing multiple un-installs of two separate versions. I re-installed the latest version on one computer, and it works fine and I can open up my old files (all I reallly wanted). I also installed the old version on my other computer and it is fully functional with my old files.
            istanbul escort
