Stop 1 minute start tmer
  • Stop 1 minute start tmer
    Some times when I start a quick heat there is a 1 minute timer. How do I disable that?
    It seems you're using a heat setting template with an interheat value.
    try this:
    - go into Racer30\Media\Racing
    - then check in default.txt file: InterHeat=
    Otherwise check the heat setting template used in quick heat setting & change it as described above.
    I can make a change to ignore this parameter for quick heats.
    istanbul escort
