RACER30 MFC Application
  • RACER30 MFC Application
    Hi all. all of a sudden, last day or 2, UR30 keeps crashing.
    RACER30 MFC Application has stopped working.
    screen shot,
    Any ideas on why? Windows 7 ultra, 64bit, 4Gig Ram, Running under administrator. on a 1T HDD.
    Sensors, Phidgets 1102 control board Phigetts 1012_2, USB 2,
    TIA, Andy
    When does it happen?
      Cannot say, its unpredictable. Sometimes at opening, others when you go into race mode. Or, just when it pleases.
        Can you send the file log.txt (in racer30 folder) at support@uracer.org?
        (just after the error message)
          Okay, will do. It seems more like a Windows Error. going to look at it later today. Will let you know the outcome.
          Hi. I think I may have solved this problem, with Ricky Torpedo help.
          Quote…. this log points out memory issue.
          I have replaced the memory within the system and no crash so far. And that’s about 1000+ laps recorded. Seems there was some duff memory.
          However, I’ll keep testing and let you all know results.
          Still cannot get the Inters to flash up, work. All sensors work within UR30 in hardware page. But nothing triggers when in a race. Have checked all that I can find within UR30 that should control the inters. Puzzled. Help please.
          Andy
          Last edited by 9000CSE; 11-24-2013, 11:40 AM. Reason: Solved, RACER30 MFC Application
          deneme bonusu
