parallel pin out for 8 lane track needed
  • parallel pin out for 8 lane track needed
    Hello. my local tracks ancient computer bailed out on us last week, and I got it limping along so I figured now would be a good time to upgrade everything. The track is 8 lanes using a dead strip but the old connection is a db25 serial. I have looked for what pins I need to use for the parallel connector but nothing goes past 4 lanes. what pins do I need to use for lanes 5-8?
    thanks.
    figured it out, the pins are in the program for each lane. seems like there is lots of customization you can do.
      right.
      go on: hardware settings -> hardware, then for each event "Detected slot car xxx" configure a // port detection pin and carry out tests from this setup screen.
      Input pins available: 10, 11, 12, 13, 15 (default)
      1, 14, 16, 17 available inn standard mode
      deneme bonusu
