If this is your first visit, be sure to
check out the FAQ by clicking the
link above. You may have to register
before you can post: click the register link above to proceed. To start viewing messages,
select the forum that you want to visit from the selection below. This Forum is brought to you by ScaleRacing LLC and their Store www.132slotcar.us
Unfortunately I am running an older version and do not have this option. New version seems to be a pain on my system and I end up with windows everywhere!! System is running Windows XP. I guess I can live with Just a Low fuel warning on the race screen.
Low fuel sounds can be assigned to the Driver, Car or as a circuit sound. Ur30 prioritizes sounds.
Ex. The driver event sound "Low fuel event" is played first if defined for the specific driver. Otherwise its slot car low fuel event sound is played if defined, if not the circuit "Low fuel event" sound is played.
The first sounds to configure are normally circuit sounds as they're managed as default sounds for any of the events listed, (ensures a universal sound will be played).
However a Driver specific or Car specific (as set on [Sounds] tab for Driver {F4} or Car {F5} can over ride (play instead of)) the circuit sound if assigned.
Note: The heat setting check box "Sounds on/off" enables or disables ALL sounds for a heat, it MUST be checked for any sounds to be played. Then the "Enabled" box must be checked with a corresponding filename or speech to say on the specific event for Driver, Car or Circuit. The "PLAY" button is just to preview the right clip is attached.
Version 31b2 - {F2} Circuit Settings [Circuit Sounds] has 2 Fuel events that are crossed (mislabeled), "Out of Fuel Warning" is played when LOW fuel light comes on, "Slot Car Fuel Low" is played when OUT of FUEL is reached.
